Macbook Pro 15" A1707 820-00928-04 no chime,no boot,no image 19.92v 0.900a
  • gugutm
    • Apr 2019
    • 16
    • London
    Hi everyone
    Please bear with me as I am not yet a pro with some of these issues. Trying to watch a lot of youtube videos and master myself but there are things which I cannot fix and would like to ask for a help from the pro people.
    Got macbook a1707 board no 820-00928-04
    It had a water damage on couple components, green staff corrosion,
    C7680 ppbus _hs_oth3v3, tested for short I believe its okey red prob on ground, getting 2.512kilo om
    C7251 ppbus_hs_cpu done the same and getting about the same, 2.506kilo om
    U5400 some corrosion, I clear all this places as much as I could with an isopropyl alcohol and tried to power on to see what is going on.
    I can see fans spins, but no light on a touch bar, keyboard caps lock not working, no light on a screen I try to connect to hdmi, but not working,
    My amp meter shows 19.92v and from 1.161a to 1.166a fluctuating this is when screen was connected and when I disconnected and take motherboard out I am getting 19.97v 0.900a
    PP3V3_G3H (R6923 - either side of the 0 ohm resistor) 1.791 kilo om
    PPBUS_G3H (F7000, pin # 2) 2.530 and going up kilo om
    Here is some s0 rails I just measured
    Ppcc_s0_cpu 0.670v this is I believe not okey I think it should be 1.2v correct me if I am wrong
    i tried to measure in a resistance mode i believe a c1073 because it is on a ppcc_s0_cpu and on pin 1 i am getting red prog on ground 003.9 om but i know from video that around cpu resistance could be low.
    Pp5v_s0 5.1v
    Pp3v3_s0 3.3v
    Pp3v3_s0_gpu 3.3v
    Pp1v8_s0 1.79v
    Try to upload as much info as I can to speed up a fix process if it is possible to fix it, read all badcaps forum about this model, also rossmanngroup forum.
    looked in wiki done some reasearch but now came to the point i need your help guys please.
    many thanks
    gugutm
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Macbook Pro 15" A1707 820-00928-04 no chime,no boot,no image 19.92v 0.900a
    Hi did ypu reflow the area where was corrosio do you have pictúres from the area with corrosion it can be thatpads from area where corrosion was not making good contact anymore.
    • gugutm
      • Apr 2019
      • 16
      • London
      no i did not reflow it i might need to do it
      sorry made a mistake it wasnt u5400 it was u7900 my bad sorry for misleading information i uploaded a picture before and will add what is looks like now
      i reflow the u7900 so on the pin 1 i am getting 12,56v on a pin 8 1.2v looks okey . to me
      • gugutm
        • Apr 2019
        • 16
        • London
        Any help? please i would really appreciate it
        • mon2
          • Dec 2019
          • 14246
          Voltage to ground of PPBUS_G3H?
          • gugutm
            • Apr 2019
            • 16
            • London
            Good morning
            power connected and on r6907 pin 1 and 2 12.63v
            i tried to measure in a resistance mode i believe cb703 pin1 red prob to ground 000.0 om
            i am confused does it mean short
            or i am doing something wrong ?
            i read another post about this motherboard and you asked the same question so i done on f7000 pin 2 and i am getting 000.0 om
            many thanks
            • mon2
              • Dec 2019
              • 14246
              Never have power to the board while measuring resistance or diode mode readings.
              Remove all power. Meter in resistance mode. Measure the resistance to ground of the same fuse. One probe on one side of the fuse. Other probe to ground. What is the reading?
              Then repeat for the other side of the same fuse. We want to check if there is a shorted part and also checking if the fuse is ok.
              Next, meter in dc volts mode of 20v or higher or auto adjust setting. Apply the power adapter.
              Red probe to the same fuse. Ground probe to ground.
              What is the voltage measurement? Repeat with red probe on the other side of the fuse.
              • gugutm
                • Apr 2019
                • 16
                • London
                ok I am sorry i will take this in mind never have power while i am measuring resistance or diode mode
                please accept my apologies and thanks for help
                lets start again
                f7000 in beep mode no power red pin 1 black pin 2 beeps and shows 000.5om
                f7000 in beep mode no power black pin 1 red pin 2 beeps and shows 000.4om
                resistance mode auto f7000 red prob on ground black prob on pin 1 2.550 kom
                resistance mode auto f7000 red prob on ground black prob on pin 2 2.550 kom
                power on amp meter shows 19.99v 0.880/0.890a
                20v dc auto f7000 pin 1 12.56v, pin 2 12.63v
                f7001 got same readings pin 1 and 2 12.63v
                • mon2
                  • Dec 2019
                  • 14246
                  Is the current draw on the power adapter side instantaneous and spikes to the peak voltage upon connecting (turn on) or does it climb up slowly to the posted values?
                  • gugutm
                    • Apr 2019
                    • 16
                    • London
                    when i plug amp meter it shows 14.58v then jumps to 20.14 1.317 a an gradually, few sec goes to 19.99 to about 0.890a
                    • mon2
                      • Dec 2019
                      • 14246
                      Fault maybe a defective GPU.
                      See the case study here:
                      https://repair.wiki/w/A1707_2016-201...ar_MacBook_Pro
                      • gugutm
                        • Apr 2019
                        • 16
                        • London
                        no this is going be beyond my limits i can try reboil it but not to change , thank you for your help Mon2
                        shame i could not fix it
                        • mon2
                          • Dec 2019
                          • 14246
                          Do wait on other comments but a sudden spike of current on the power rail often indicates a shorted / partially shorted component.
                          TBH - even after investing into a rather high end Seamark BGA rework station (paid more than the car I am driving) - still afraid of the process. Removing BGA devices is a dream with the tool we have as it is fully automated. Recently had the tool calibrated for the proper placement of a fresh device. BGA devices are almost in our comfort zone with this tool but not yet with WLCSP packaged devices which are wafer thin. During the pickup process, the suction nozzle cracked the fresh component due to the travel height action. Still learning.
                          Do check the EDP_PANEL_PWR_EN voltage to ground as well to confirm the above case. Plan B is to treat this board as a donor board.
                          • spidertnt
                            • Jul 2016
                            • 34
                            second picture looks like possible burnt pins on the flex display connector ?...when this happens the screen side connector also needs replacement.
                            The burning usually damages the GMUX chip and it will also need replacement .
                            • leonemax81
                              Macbook a1707 820-00281 Battery no Power
                              by leonemax81
                              Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                              08-23-2024, 09:24 AM
                            • sofles
                              Macbook a1707 2017 model 820-00928 GPU issue
                              by sofles
                              Hello there
                              I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                              I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                              11-21-2024, 05:25 AM
                            • baglaivlad
                              MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
                              by baglaivlad
                              Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
                              Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
                              01-09-2024, 09:55 PM
                            • Aliseo
                              Macbook Pro 15" A1707 820-00928 no chime,no boot,no image
                              by Aliseo
                              Hello, I'm working on a 2017 15 inch macbook with motherboard 820-00928.
                              Board is look good, no signes of liquid damaged.
                              The motherboard takes 20V 1.1A (without battery) but it doesn't start, the trackpad works, caps lock doesn't light up, the fans spin and with an external monitor nothing is shown.
                              I excluded the usb C area because it takes 20V, I measured the voltages on the big coil, I receive all the voltages, GPU and CPU heat up regularly
                              PPVCORE_S0_GPU is 0.9V
                              I tried to flash a new bios but the result is
                              12-14-2022, 04:50 AM
                            • tommy97
                              Apple MacBook A1707 No Audio/Sound
                              by tommy97
                              I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                              I've also replaced U6300, but the problem persists.
                              Here are the current voltage readings:
                              • PPV18_S0: 1.8V
                              • R6402: 1V
                              • R6405: 1V
                              • R6403: 1V
                              • AUD_SPKRAMP_RESET_L: 1.3V
                              • PPBUS: 12.6V
                              03-10-2025, 11:22 AM
