Need help with diagnosing macbook 820-00138-A
  • survivalbloke
    • Aug 2021
    • 302
    Macbook Pro A1398 EMC2909 SN: C02VW1C9G8WN
    He said he spilled water on the kb, and now won't power up. When connected to the bench, it's taking 313ma. Pressing the power button reduces that to 310ma.
    I found some water damage corrosion(very light) and cleaned it off. That did not fix the issue and I did not find any other visual problems.
    I do get a green/amber light on the power adapter.
    Where do I go next with this?
  • ACS-Repair
    • Feb 2021
    • 204
    Re: Need help with diagnosing macbook 820-00138-A
    Have you ruled out a bad keyboard?
    I've bought a couple of MacBooks that would not power on with the power switch but found they would power on if I disconnected the battery and connected the MagSafe. This confirmed the keyboard was the issue.
    • TimSinger
      MacBook Pro M4 16" A3403 on the table with water damage
      by TimSinger
      Hi guys,
      I have a MacBook Pro M4 16" A3403 on the table with water damage. I allready found the problem within a bad cap. As far as my researh went, I couldn't find the schematics and boardview for this MacBook model. They seem not to be released now. So my question is if anybody has a working A3403 on the table and could tell me, which specification this capasator has?
      I attached a photo of the missing cap. It's on the bottom side of the logicbard.
      I am very thankful for your replys.
      Thanks in advanced and best regards from Hamburg Germany...
      07-13-2025, 11:12 AM
    • dbuergi
      Water damaged MacBook Air A1932 AmrestoreErrorDomin Error-9 trying to restore with configurator
      by dbuergi
      this Macbook was stuck at 5v and didn't start because of some water damage. I was able to clean everything and the board started. So i put everything back together and the Macbook seems to boot with 20v, 1,4A and 29W. So i decided a DFU recovery. At 50% of the system repair i get the error massage from the title. Display stays black and no Apple logo. Both repair and recovery don't work.
      Is there anything i can do?
      11-19-2024, 09:27 AM
    • dbuergi
      Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
      by dbuergi
      i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
      Any ideas where to look?...
      11-07-2024, 10:57 AM
    • Grandoni Manuel
      MacBook a2289 water damage
      by Grandoni Manuel
      Hello to all ! I follow you but this is first time write !!
      your forum is the best !!
      so I’ve a2289 with water damage ! In first time other friend have clean and work ! But after some time stop working !
      now, I open the MacBook and I see a lot of corrosion near backlight circuit (I attach some photos about that ) I think the problem is on backlight maybe bcs do strange boot then reboot (attach video ) I change some thing on the circuit like :
      q8400
      q8401
      D8410
      and the resistor R8431
      if I check PPVIN SOSW LCDBKLT_R I’ve 12,9v
      on...
      04-03-2025, 06:45 PM
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
