Macbook pro 14 A2442 power supply blink
  • donzaucker
    • Jun 2023
    • italy
    the mac in question suddenly no longer turns on and the magsafe led flashes orange.
    Doing some checks I noticed with the thermal camera that the voltage regulator of the nand0 UN400 (338S00600) heated up a lot, around 80°C. I thought about replacing it, I only found it from some seller on aliexpress.
    Once replaced, the problem is always the same, but the chip now doesn't heat up anymore and no output voltage is present. Has anyone had experience with this? Could the purchased chip be a fake?
    Thanks for your help!
  • flyhotstuff
    • Mar 2021
    • 11
    • Anguilla
    did you get this fixed?
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
    • SarcasticOP
      General question about MacBook power rails for repair.
      by SarcasticOP
      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
      • PPBUS_G3H (12.6V-12.8V)
        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
      • PP3V42_G3H (3.42V)
        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
      • PPVRTC_G3H (3.3V)
        • This
      12-12-2024, 05:50 PM
