820-01598 Won't charge (only the first time!)
  • Sajtisajti
    • Nov 2019
    • 9
    • Hungary
    Hmm 820-01598 its charge when i freshly connect the battery to the board, if i disconnect charger and connects again it will not charge..
    Without battery its works well always! (dont have another battery to try with)
    C7034 was blowen up, thats PPDCIN_G3H_CHGR.
    Is there a way that Q7030 damaged in the process and can do that?
    I could not find short to gnd.
    When its not charge its shows 20.48V 0.041A On F7000 i can measure 11V only.
    Any idea?
  • mon2
    • 14758
    Re: 820-01598 Won't charge (only the first time!)
    Review Q7065 mosfet.
    Remove all power. No battery. Meter in resistance mode.
    Measure the resistance between
    Source and drain
    Source and gate
    Gate and drain
    Post each measurement.
    • Sajtisajti
      • Nov 2019
      • 9
      • Hungary
      Hey! Thank you for your help
      Sure no pwr on board
      Source and drain: (Red Pin 1-2-3 and black pin 5)
      Something is chargeing up. i put the probe there with 80kOhm function. its shows 60kOhm and increase, there is no constant ohm there.
      If i set 800kOhm setting its shows 460kOhm..
      In diode red probe on pin 1-2-3 black probe at pin 5 it 1.860
      If i change probes its 0.133
      Source and gate at resistance
      Red probe on pin1-2-3 black on pin4 constant 10MOhm
      changed polarity 2.7MOhm
      In diode Red probe on pin1-2-3 black on pin4 1.740
      changed polarity 1.100
      Gate and Drain resistance
      Red on pin 4 black on pin 5 5.5MOhm
      reverse 2.96MOhm
      in diode Red on pin 4 black on pin 5 2.240
      reverse 1.746
      Update:
      Meanwhile, another such machine came in. Its act like same with another battery, i cant compare the two boards atm cos its has short to gnd on ppbus_g3h and they need to order the repair. :/ Atleat the battery is good.
      • Sajtisajti
        • Nov 2019
        • 9
        • Hungary
        Update 2
        When i have done smc reset its started to charge again and left that 20.20v 0.049-0.037A state. May i need to run a dfu?
        • Sajtisajti
          • Nov 2019
          • 9
          • Hungary
          Damn, tried a bunch of stuff. I think its a T2 problem. Tried revive with dfu, same shit.
          Replaced U7000 too, nothing. Same stuff. : /
          • ipatch
            troubleshooting microsoft surface pro 4 no power no led charge light
            by ipatch
            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
            10-05-2023, 11:59 AM
          • ruletero
            Acer a515-43 low battery charge voltage
            by ruletero
            Hi
            Acer A515-43
            LA-H801P
            Fail: Does not charge battery, has low voltaje on connector.
            Laptop didn't want to turn on, only charge led blinked.
            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
            10-24-2022, 02:31 PM
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • Klevjetack
            Charge a L19D3PDA battery externally from the laptop
            by Klevjetack
            Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
            03-05-2024, 07:26 AM
          • razenxd
            How can I charge that battery pack?
            by razenxd
            it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
            At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
            Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
            Now, I have noticed a few things.
            The "dead" battery, while connected to charger and NOT Charging will...
            12-05-2024, 06:11 AM
