Lenovo E540 no 3/5valw
  • techyhomer
    • Jul 2023
    • 7
    • Moon
    I have an aile2 nm-a161 rev 1.0 board that IO ITE8586 and 3/5v regulator was defective so I Have replaced the IO with a new programmed one, but when I replaced the regulator I did not get the 3/5v on the inductors
    and here are the readings from the IC:
    1 FB1 0
    2 ENTRIP1 0,9
    3 TON 2
    4 ENTRIP2 1,5
    5 FB2 0
    6 PGOOD 0
    7 BOOT2 4,5
    10 LGATE2 0
    9 PHASE2 0
    8 UGATE2 0
    11 VIN 20
    12 ENLDO 3,2
    13 ENM 1,3
    14 LDO5 5
    15 LDO3 3,3
    16 LGATE1 0
    17 PHASE1 0
    18 UGATE1 0
    19 BOOT1 4,5
    20 BYP1 0
    All the components around the IC are good, as far as I have checked. Can you guys help me discover the problem?
    Schematic ---> https://www.badcaps.net/forum/showthread.php?t=88932
    Last edited by Vesko356; 07-23-2023, 04:38 PM. Reason: Attached schematic removed and replaced with link.
  • mon2
    • Dec 2019
    • 14331
    Re: Lenovo E540 no 3/5valw
    These rails are powered by the B+ rail which is present only after the 2*DCin mosfets are enabled.
    For this reason, check the voltage to ground of the 2*DCin mosfets. Interested in the source / gate / drain pin voltages to ground (pq301 / pq304).
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      Originally posted by techyhomer
      I have an aile2 nm-a161 rev 1.0 board...
      Do not attach laptop schematic and/or BV in this section please!
      Schematic Requests ONLY!
      https://www.badcaps.net/forum/forumdisplay.php?f=41
      Reminder: rules and organization of this section
      https://www.badcaps.net/forum/showthread.php?t=117483
      If you request/offer BIOS/schematics/boardviews, please post in the appropriate subsection, and you can link to it in the troubleshooting topic.
      Become a Badcaps supporter
      Thanks to all supporters.​
      • techyhomer
        • Jul 2023
        • 7
        • Moon
        Hi, I have measured all the mosfets before. pq301 / pq302 only the B+ is present on pin 5. For pq303 pq304 no voltage at all.
        • Udemzy
          • May 2017
          • 161
          • Guatemala
          Since entrip is available, replace the polarized capacitors but your Pin 13 is 1.3v which is wrong.
          • techyhomer
            • Jul 2023
            • 7
            • Moon
            According to the data sheet of RT8243A having 1.2V to 1.8V on Pin 13 will activate the switching mode on ASM==Audio Skipping Mode==Ultrasonic Mode. For the polarized capacitors I have checked and the they have no short. I wonder if I can run the IC without the caps to see for seconds if their is any voltage on conductors, since I cannot get hold of new caps right now.
            • techyhomer
              • Jul 2023
              • 7
              • Moon
              I have replaced the RT8243A with a used one, but the readings I got was very faulty even it did not have any short. I went back to the original RT8243A, but I want you guys to confirm if it is safe to run the IC without the caps? since I have removed the jumpers PJ402 PJ403.
              For the pin 13 ENM what is the ideal voltage, should it be 3.3v?
              I was planning to remove PR420 and connect ENM with LDO5 to see if the IC is faulty or not. is it a good idea?
              Pressing the power btn does not lead to any change though 3vl is present.
              On PD401 pin1 I have 2.7 volt but on pin2 I have 1.3v!
              • techyhomer
                • Jul 2023
                • 7
                • Moon
                I have replaced the RT8243A IC twice but every time I get PQ401 and PQ403 mosfets shorted and burned. The IC has no voltage on outputs or very low voltage though VIN 19.5 and ENLDO 3,2 are present.
                • GabrielS24
                  Lenovo E540 battery problem
                  by GabrielS24
                  Hello! I'm here to look for solutions to reset the EEPROM memory of a Lenovo E540 battery of 62Wh and 540mAh. I even bought a new one on the market (aftermarket BTIBM30) because I couldn't find an original one but it doesn't work. The laptop sees the percentage but blocks the battery charging probably because of the Chinese BMS. In the bios I don't have an option for the battery and I didn't find an older version (v1.57). I replaced the Lenovo BMS with Chinese cells but in windows it doesn't read the battery percentage and says it needs to be changed. I have 12v between D and the red wire....
                  04-16-2025, 05:23 AM
                  Lenovo 3000 Series Schematic
                  Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                  3000 C100 laptop with Braille keyboard
                  Lenovo 3000 C
                  C100, C200 - 15-inch XGA screen
                  Lenovo 3000 N
                  N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                  N500 - 15.4 inch screen.
                  Lenovo 3000 V
                  V100, V200 - 12.1-inch WXGA models
                  Lenovo 3000 G
                  G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                  10-04-2024, 06:05 AM
                  Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                  This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                  09-06-2024, 06:40 AM
                  This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                  09-06-2024, 06:06 AM
                • derradji89
                  Need help Lenovo MIX 320-10lCR domaine name SERCOL
                  by derradji89
                  Hi everyone 🤗
                  I have a Lenovo MIX 320-10lCR computer.**
                  1. **Operating System**: Windows 10 ** Education** 64-bit.
                  2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                  3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                  4. **BIOS Chip Reflashing**: Currently,...
                  04-19-2025, 03:04 PM
