HP 14-bp151sa Screen Turn Off Issue
  • ianbak
    • Apr 2023
    • 52
    I have an HP 14-bp151sa running Windows 10 which has a very strange fault. It works absolutely perfectly until the screen sleep timer expires and Windows turns the screen off (it correctly follows the delay set in Windows for this). After that, neither the keyboard, trackpad or USB mouse will turn the screen back on, meaning that the computer is effectively hung. The caps lock button doesn't light when pressed, although I can still hear the fan running normally. A long press on the power switch to force a power down is the only way to get the system working again.
    Things I have already tried:
    - Updating to the latest BIOS
    - Resetting the BIOS to default values
    - A fresh install of Windows 10 (plus full updates)
    - Checking for driver issues - there are none
    - Checking that the keyboard and mouse drivers are set to 'Allow this device to wake the computer'
    What could I be missing?
  • ianbak
    • Apr 2023
    • 52
    Re: HP 14-bp151sa Screen Turn Off Issue
    OK, I managed to find an identical system running Windows 11 and swapped the discs over. The previously faulty system is now fine, and the Windows 11 system - which was OK - is now exhibiting exactly the same fault! So it looks like a software issue, but using Windows 11 is an acceptable workaround.
    • benek123
      RedmiBook 15 pro 2023 Ryzen - after replace LCD screen work only in windows
      by benek123
      I replaced the screen and LCD ribbon in Redmi Book 15 Pro Ryzen 2023. After replacing, the image on the screen is only visible in Windows 11 - when the AMD drivers are loaded.
      The screen is backlit but there is no image in: bios, post, when loading windows, in linux (ubuntu boot from usb), windows 10 PE.
      When I disconnect the EDP connector from the board and connect the HDMI cable, the image is visible everywhere good, in the BIOS you can see 2/3 of the image, i.e. 1920 pixels out of 3000 pixels.
      I checked the EDID with the old screen - it is identical.
      What...
      09-24-2024, 03:28 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • DynaxSC
      ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
      by DynaxSC
      I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
      Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
      Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
      The behaviour is also really very strange, i.e.:
      • The disk shows always up in BIOS - so it is recognized, so far so good
      • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
      02-23-2025, 01:33 PM
    • SuperJames
      Dell G3 17 3779 Weird power cycling and shutdown/restart issue
      by SuperJames
      This one's a weird one, and still unsolved despite it having gone back to Dell once.
      Specs
      i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
      Backstory
      I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
      10-23-2023, 04:09 PM
