Asus GU502GU no powering up
  • Garibean
    • Apr 2022
    • 47
    • France
    Hi !
    I'm becoming crazy for this one, i have a non working asus GU532GV-ES023T.
    I checked for short on the main power rail and couldnt find anything.
    Then i checked +nvvdd for the gpu and found a short (0,1 ohm maybe a little more), but i learned later that it's normal for a gpu to have a resistance this low.
    I checked the cpu and got 2 ohm, it's also normal here.
    I noticed that someone have already worked on it and found a short between 3vadsw_LG_30 and gnd.
    The last person made a short between this line and gnd on a mosfet. I resolved the short with my iron and thinking that it would do it, i plugged the pc on.
    Nothing, i checked with my thermal camera and saw that a small ic is getting hot : PU8701 aka sn51285arukr.
    I am kind of stuck here because i don't know if replacing it will resolve my problem... can i remove it and check for short then ?
  • mon2
    • Dec 2019
    • 14231
    Re: Asus GU502GU no powering up
    If this component is getting hot, remove all power -> measure the resistance to ground on the output of this IC. What is the resistance reading ?
    https://cdn.badcaps-static.com/pdfs/...8733694997.pdf
    • Garibean
      • Apr 2022
      • 47
      • France
      So i found 7 ohm on the pin 12 (Vin) +5VAO, so it does mean that i need to check here ? Do i need to do voltage injection on this pin ?
      also here are the schematics
      Schematic and boardview ---> https://www.badcaps.net/forum/showth...67#post1142867
      Last edited by Vesko356; 07-11-2023, 05:35 PM. Reason: Attached schematic and BV removed and replaced with link.
      • Sephir0th
        • Oct 2020
        • 1282
        VIN is +AC_BAT_SYS, so the Main Power rail. It is impossible to have the Main Power rail present with a 7 Ohms to GND there.
        FairRepair on YouTube
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Do NOT attach schematics here!
          Reminder: rules and organization of this section
          https://www.badcaps.net/forum/showthread.php?t=117483
          Become a Badcaps supporter
          Thanks to all supporters.​
          • Garibean
            • Apr 2022
            • 47
            • France
            I'm really sorry for that, i will not do it again. Thank you for the link !
            I found a ic that was hot with voltage injection, i removed it, now i have 60 ohm to GND on this main power rail, could it be this one ?
            I tried to look, on the ic that i removed, for any short circuit and found 1.5 ohm to the GND of the IC, is it normal ?
            For precision, it was this one APL5930QBI-TRG aka PU8602 ont the schematics
            • myth77
              • Feb 2017
              • 380
              • Croatia
              On main power rail resistance have to be in kilohms. How much voltage did you inject and how much current it is drawing?
              • Garibean
                • Apr 2022
                • 47
                • France
                I injected 1volt 3 amps but it was taking 0.7amps
                I check and i have 60 ohm the +3v line too
                • Garibean
                  • Apr 2022
                  • 47
                  • France
                  Do you have any ideas ?
                  • Sephir0th
                    • Oct 2020
                    • 1282
                    60 Ohms at +3VALW/+3VS is usually a bad sign. Since with 1V likely nothing will significantly heat up from a 60 Ohms short (except thermal camera available), feel free to inject 3V 3 Amps and see what is getting hot, especially the PCH.
                    • Garibean
                      • Apr 2022
                      • 47
                      • France
                      So little update ! I continued searching and found 0 ohm on the +1.05vsus ! On the schematics, it looks like it's linked to the pch so i tried voltage injection and the pch was hot...
                      It's the hm370 sr40b, i will try to change it and hope that it works.
                      Do you think that it's the pch ?
                      • mon2
                        • Dec 2019
                        • 14231
                        Yup. Game over.
                        • Garibean
                          • Apr 2022
                          • 47
                          • France
                          The good news is that i found why there was 60ohms on ac_bat_sys, a mosfet was shorted, now i have kohms on the main power rail !
                          Do you think that it's worth it to change the pch ? I'm planning to buy a pre heater to change bga chips
                          I have also an other question about the +NVVDD being 0.1ohm, i am not making any mistakes here, this is normal to have 0.1ohm ?
                          • Sephir0th
                            • Oct 2020
                            • 1282
                            If you have to ask, don't try it...
                            • Garibean
                              • Apr 2022
                              • 47
                              • France
                              I am learning sorry ^^
                              I read a lot that it's 50/50 when replacing a pch, i even saw a youtuber called Sorin that changed a sr40b with only a hot air station.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Never try those gimmicks of replacing a PCh with hot air gun. Only a BGA machine can do this job perfectly. The shorted mosfet was a high side fet on VCORE circuit?
                                • Garibean
                                  • Apr 2022
                                  • 47
                                  • France
                                  PQH8702 was shorted, this mosfet was taking care of 3vadsw, next to it was pql8703 which was shorted because the last person didn't do a good soldering job and shorted the 3vadsw of the mosfet to gnd (that explain maybe the death of pqh8702 which was in front of pql8703)
                                  • Garibean
                                    • Apr 2022
                                    • 47
                                    • France
                                    Hi, little update, the pch was shorted. I asked a friend of mine who works in an electronic school to change it with the bga repair station. He successfully changed it but detected 1 short in the X-Ray machine. I told him to give up because that was a pain since the beginning.
                                    Thank you every one for your help !
                                    • Andri15
                                      • Jul 2024
                                      • 39
                                      • indonesia
                                      what is the suitable equation for ic sn51285arukr?
