Asus GU502GU no powering up
  • Garibean
    • Apr 2022
    • 47
    • France
    Hi !
    I'm becoming crazy for this one, i have a non working asus GU532GV-ES023T.
    I checked for short on the main power rail and couldnt find anything.
    Then i checked +nvvdd for the gpu and found a short (0,1 ohm maybe a little more), but i learned later that it's normal for a gpu to have a resistance this low.
    I checked the cpu and got 2 ohm, it's also normal here.
    I noticed that someone have already worked on it and found a short between 3vadsw_LG_30 and gnd.
    The last person made a short between this line and gnd on a mosfet. I resolved the short with my iron and thinking that it would do it, i plugged the pc on.
    Nothing, i checked with my thermal camera and saw that a small ic is getting hot : PU8701 aka sn51285arukr.
    I am kind of stuck here because i don't know if replacing it will resolve my problem... can i remove it and check for short then ?
  • mon2
    • 14997
    Re: Asus GU502GU no powering up
    If this component is getting hot, remove all power -> measure the resistance to ground on the output of this IC. What is the resistance reading ?
    https://cdn.badcaps-static.com/pdfs/...8733694997.pdf
    • Garibean
      • Apr 2022
      • 47
      • France
      So i found 7 ohm on the pin 12 (Vin) +5VAO, so it does mean that i need to check here ? Do i need to do voltage injection on this pin ?
      also here are the schematics
      Schematic and boardview ---> https://www.badcaps.net/forum/showth...67#post1142867
      Last edited by Vesko356; 07-11-2023, 05:35 PM. Reason: Attached schematic and BV removed and replaced with link.
      • Sephir0th
        • Oct 2020
        • 1289
        VIN is +AC_BAT_SYS, so the Main Power rail. It is impossible to have the Main Power rail present with a 7 Ohms to GND there.
        FairRepair on YouTube
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Do NOT attach schematics here!
          Reminder: rules and organization of this section
          https://www.badcaps.net/forum/showthread.php?t=117483
          Become a Badcaps supporter
          Thanks to all supporters.​
          • Garibean
            • Apr 2022
            • 47
            • France
            I'm really sorry for that, i will not do it again. Thank you for the link !
            I found a ic that was hot with voltage injection, i removed it, now i have 60 ohm to GND on this main power rail, could it be this one ?
            I tried to look, on the ic that i removed, for any short circuit and found 1.5 ohm to the GND of the IC, is it normal ?
            For precision, it was this one APL5930QBI-TRG aka PU8602 ont the schematics
            • myth77
              • Feb 2017
              • 380
              • Croatia
              On main power rail resistance have to be in kilohms. How much voltage did you inject and how much current it is drawing?
              • Garibean
                • Apr 2022
                • 47
                • France
                I injected 1volt 3 amps but it was taking 0.7amps
                I check and i have 60 ohm the +3v line too
                • Garibean
                  • Apr 2022
                  • 47
                  • France
                  Do you have any ideas ?
                  • Sephir0th
                    • Oct 2020
                    • 1289
                    60 Ohms at +3VALW/+3VS is usually a bad sign. Since with 1V likely nothing will significantly heat up from a 60 Ohms short (except thermal camera available), feel free to inject 3V 3 Amps and see what is getting hot, especially the PCH.
                    • Garibean
                      • Apr 2022
                      • 47
                      • France
                      So little update ! I continued searching and found 0 ohm on the +1.05vsus ! On the schematics, it looks like it's linked to the pch so i tried voltage injection and the pch was hot...
                      It's the hm370 sr40b, i will try to change it and hope that it works.
                      Do you think that it's the pch ?
                      • mon2
                        • 14997
                        Yup. Game over.
                        • Garibean
                          • Apr 2022
                          • 47
                          • France
                          The good news is that i found why there was 60ohms on ac_bat_sys, a mosfet was shorted, now i have kohms on the main power rail !
                          Do you think that it's worth it to change the pch ? I'm planning to buy a pre heater to change bga chips
                          I have also an other question about the +NVVDD being 0.1ohm, i am not making any mistakes here, this is normal to have 0.1ohm ?
                          • Sephir0th
                            • Oct 2020
                            • 1289
                            If you have to ask, don't try it...
                            • Garibean
                              • Apr 2022
                              • 47
                              • France
                              I am learning sorry ^^
                              I read a lot that it's 50/50 when replacing a pch, i even saw a youtuber called Sorin that changed a sr40b with only a hot air station.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Never try those gimmicks of replacing a PCh with hot air gun. Only a BGA machine can do this job perfectly. The shorted mosfet was a high side fet on VCORE circuit?
                                • Garibean
                                  • Apr 2022
                                  • 47
                                  • France
                                  PQH8702 was shorted, this mosfet was taking care of 3vadsw, next to it was pql8703 which was shorted because the last person didn't do a good soldering job and shorted the 3vadsw of the mosfet to gnd (that explain maybe the death of pqh8702 which was in front of pql8703)
                                  • Garibean
                                    • Apr 2022
                                    • 47
                                    • France
                                    Hi, little update, the pch was shorted. I asked a friend of mine who works in an electronic school to change it with the bga repair station. He successfully changed it but detected 1 short in the X-Ray machine. I told him to give up because that was a pain since the beginning.
                                    Thank you every one for your help !
                                    • Andri15
                                      • Jul 2024
                                      • 46
                                      • indonesia
                                      what is the suitable equation for ic sn51285arukr?
                                      • OOF DIO
                                        ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                                        by OOF DIO
                                        (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                                        (Had 3 problems, now just 1)
                                        I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                                        I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                                        I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                                        04-19-2025, 05:03 PM
                                      • kara
                                        Asus GX501v keyboard not working - keyboard firmware - solved!
                                        by kara
                                        Hello, i had a problem with this laptop keyboard. not working even after replacing with new original palmrest.
                                        Solution after hours of researching is using a small software found on asus forum !
                                        https://rog-forum.asus.com/t5/rog-ga.../701169/page/6
                                        Thank you Bogdan Ciulei
                                        Finally some good news :
                                        I have managed to fix the problem.
                                        First,
                                        I am not responsible for any damage you might do to your hardware !
                                        YOU DO THIS AT YOUR OWN RISK ! I ONLY PROVIDE POINTERS , DO
                                        12-09-2025, 02:27 AM
                                      • jkucukov
                                        Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
                                        by jkucukov
                                        I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
                                        During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
                                        02-05-2025, 09:27 PM
                                      • nyar2
                                        ASUS G513Q short on 1.8 and 0.75v rail
                                        by nyar2
                                        I have this laptop that initially had a short on VBAT
                                        I found that the short was coming from U60600, a DC/DC converter responsible for 1.8v. There was also a shorted cap on pin 13, the LDO for the chip.
                                        Removing these has cleared the short on VBAT. But 1.8v and 0.75v rail read 0.1 OHMS.
                                        I have read another article here that said that this typically indicates a failed cpu.
                                        Is there any way to confirm? I was borrowing a thermal cam and now don't have one to see what heats up on that rail. I feel like I may be wasting my...
                                        11-26-2025, 10:51 PM
                                        ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                        09-07-2024, 02:50 AM
