HP 15-bw065 (LA-E831P) no EC_ON signal
  • Xruss
    • Dec 2020
    • 9
    • Казахстан
    HP 15-bw065 (LA-E831P) malfunction: no EC_ON signal from the cartridge.
    Trouble: the laptop did not turn on, there was no 19v at the output from the keys on the charger.
    They replaced transistors PQB11 and PQB12 - 19v appeared.
    But now KB9022 cartridge doesn't output EC_ON 3,3v when I pressed the power button on the notebook.
    The power supply of the cartridge is normal.
    On the legs: 9, 22, 33, 67, 96, 111, 125 - 3,3v
    On pins: EC_ON, EC_KBRST#, PM_SLP_S3#, PM_SLP_S5#, PCH_PWROK, SPOK, SYSON, EC_RSMRST#, MAINPWON, SUSP#, VGATE - [b]0v.
    On the legs: 0. 95VS_PWR_EN#, EC_TX/GPIO16, SUSP_LED#/GPIO19, EC_RST#, KSI0-7/GPIO30-37, BATT_TEMP, ADP_ID, EC_SMB_CK1, EC_SMB_DA1, WL_PWREN_EC#, USB_ON#, EC_ACIN, LID_SW#, ON/OFFBTN# (when the power button is pressed, the voltage drops to 0v) - 3.3v.
    On pins: 66 and 109 (VCIN0_PH) - 2.8v
    On pins: 27 - 1.5v
    Voltages on unspecified pins are 0v or below 0.3v.
    When power supply is connected, voltage 3,3v appears on the EC_ON multiple and in 3 seconds it drops to 0v.
    I unsoldered the solder pin and fed 3.3v to the EC_ON bus, then the standby voltages appeared.
    I replaced the cartridge with a new one (I flashed it).
    Any tips for solving this problem?
    Schematic ---> https://www.badcaps.net/forum/showth...44#post1229744
    Last edited by Vesko356; 07-08-2023, 03:38 PM. Reason: Attached schematic removed and replaced with link.
  • mon2
    • 14002
    Re: HP 15-bw065 (LA-E831P) no EC_ON signal
    Hi.
    1) You will need to move the above schematic to the schematic forum to keep it organized and so that future readers can find the same.
    2) Confirm if the voltage to ground of +3VALW_EC is stable when the unit is ON/OFF.
    3) Confirm the voltage to ground on the charger IC (PUB1) of:
    REGN (pin # 16) ; should be ~6 volts
    ACOK (pin # 5)
    ACDRV (pin # 4) ; should be ~25 volts to enable the 2*DCin mosfets
    CMSRC (pin # 3)
    ACP (pin # 2) ; this and ACN are important to gauge the 'load' of the rail
    ACN (pin # 1) ; too large of a voltage drop = too high of a current consumption = turn it OFF
    • Xruss
      • Dec 2020
      • 9
      • Казахстан
      Originally posted by mon2
      Hi.
      ACOK (pin # 5)
      CMSRC (pin # 3)
      +3VALW_EC - stable 3.3v
      REGN (pin #16) - 6.07v
      ACOK (pin #5) - 3.3v
      ACDRV (pin #4) - 25v
      CMSRC (pin #3) - 19v
      ACP (pin # 2) - 19v
      ACN (pin # 1) - 19v
      • Sephir0th
        • Oct 2020
        • 1262
        You might dig into the wrong side of the road. I guess it needs healthy +3VALW and +5VALW rails for stable Enables, too
        Also with HP laptops a known working charger of correct wattage has to be ruled out.
        FairRepair on YouTube
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Does RSMRST# appears after pressing power button?
          • Xruss
            • Dec 2020
            • 9
            • Казахстан
            There is EC_RSMRST# which should appear from 1.8v voltage after starting the PU301 (+3VALWP - +5VALW).
            • Xruss
              • Dec 2020
              • 9
              • Казахстан
              The +3VALW and +5VALW buses are normal, the load is more than 700 ohms. SPOK (PGOOD), +3VALW and +5VALW appear when EC_ON appears briefly on PU301.
              • Sephir0th
                • Oct 2020
                • 1262
                So half of the important informations were hidden till now.
                If there are voltages present, even for a brief moment then you need to share this with us. Now it could be even the case that the issue is way further in the sequence. It needs a detailed observation till which point the board comes up, even if it is for a Brief moment.
                Also 700 Ohms is more than suspicious for my taste. Which power rail exactly does measure this low resistance to GND?
                • Xruss
                  • Dec 2020
                  • 9
                  • Казахстан
                  When you connect the power supply on the KB9022 EC_ON pin appears voltage 3,3v and after 3 seconds drops to 0v.
                  KB9022 pin unsoldered and fed 3.3v to the bus EC_ON, duty voltages appeared.
                  KB9022 was replaced by a new one (flashed).
                  • Xruss
                    • Dec 2020
                    • 9
                    • Казахстан
                    • mon2
                      • 14002
                      Does the logic board function normally with the EC_ON bypass method?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        I think getting EC_ON for 3 seconds and then going to zero is normal behaviour as it goes into DSW mode.It will get back to S5 state after trigerring only.
                        • Xruss
                          • Dec 2020
                          • 9
                          • Казахстан
                          I searched the internet for information on ADP_ID and found out that my opinion about it was wrong.
                          Resistance of ADP_ID relative to VDD (+19v) at 65w PSU = 383KOhm, voltage was 0.98v.
                          After restoring the correct operation of ADP_ID . Laptop worked, problem solved.
                          • mon2
                            • 14002
                            @Xruss, can you post the details of how you fixed the ADP_ID?
                            • howardc64
                              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                              by howardc64
                              Failure Symptom
                              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                              Where is the short?
                              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                              05-27-2025, 02:56 PM
                            • SS454
                              vizio e650i-a2 backlight flashes then turns off
                              by SS454
                              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                              panel: au optronics T650HVN05.4
                              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                              https://www.shopjimmy.com/vizio-56-0...-power-supply/
                              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                              08-20-2020, 03:57 PM
                            • JayPoorJay
                              Converting +/- 5v to a Usable Hz Signal
                              by JayPoorJay
                              Good morning.
                              I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                              This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                              The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                              08-07-2022, 08:35 AM
                            • supravit2000
                              PS4 fat has inconsistent signal after HDMI replacement
                              by supravit2000
                              Hi, guys!
                              I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
                              My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
                              12-19-2022, 08:08 PM
                            • corrize
                              Where to find a very small fpc connector 0.3mm between 2 pins ?
                              by corrize
                              Hello, I search this connector (oxydated).
                              It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                              I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                              I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                              Do you know how to find this connector please ? What is the exact name for find it ?
                              08-06-2024, 05:25 PM
