Nm-c371 RTC problem
  • ahmarzo
    • Mar 2015
    • 173
    • india
    Nm-c371 RTC problem
    Have motherboard nm-c371 gives display without RTC and no power on with RTC battery attached .no shorting in RTC section vccrtc 3 v
    Pchrtcrst 3v
    Pchsrtcrst is 3v
    Plz help solving this problem
  • mon2
    • Dec 2019
    • 14659
    Re: Nm-c371 RTC problem
    Review the attached section of the logic board.
    Review the voltage to ground on the dual diodes - pins 1, 2 and 3.
    Attach with RTC battery; and also measure without RTC battery.
    • ahmarzo
      • Mar 2015
      • 173
      • india
      With RTC attached pin no 1 -3v. Pin no2 -3v and pin no 3 -0v
      When RTC is removed and powered on pin 1 and 3 - 3v and pin no 2 -0v
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Nothing wrong here. If boardview is available, then search "RTC" as keyword in schematic and measure each and every point of RTC circuit. Without boardview its herculian task though.
        • Sephir0th
          • Oct 2020
          • 1289
          Please confirm, +3VL is missing with CMOS attached present, with CMOS removed? Do you have checked the diode in diode mode for sanity?
          FairRepair on YouTube
          • ahmarzo
            • Mar 2015
            • 173
            • india
            Thanks everyone after changing pd101 the voltage is same on all pins but the problem has been solved.
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
            • perzyk23
              Lenovo T580 - LCD Panel problem - error 0288
              by perzyk23
              Good morning,
              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
              10-25-2024, 12:42 AM
            • lazaro.089
              Asus Zephyrus M16 / GU603ZW problem
              by lazaro.089
              Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
              CPU: Core i9-12900H
              Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
              Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
              The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
              08-26-2025, 06:33 PM
