CLEVO P751DM - BLOWN unknown chipset
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3593
    • slovakia
    Helo.
    Have this CLEVO P751DM and i found blown chipset. cannot determine what chip it is, to replace it. Marking is only 02867. it have socket with desktop cpu i7-6700K
    • 20914
    Re: CLEVO P751DM - BLOWN unknown chipset
    Originally posted by ktmmotocross
    Helo.
    GL82Z170 possibly ?
    https://www.notebookcheck.net/Schenk....151283.0.html
    https://en.wikipedia.org/wiki/List_of_Intel_chipsets
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      https://www.e-weekly.co.uk/download/...dm_esm.pdf?lce
      here u can find the schematic. on the pch should be a code sxxx something that identify exactly what bga u need. it's part of the z170 chipset. with bios modification, cpu pin cover modification u can install till i9 9900ks cpu and better gpu too.
      i daily use the z270 version with i7 9700k and 3080 mobile mxm.
      if u repair it it's a great notebook.
      • Sephir0th
        • Oct 2020
        • 1282
        These PCHs are all printed the same way. You just have to look here. I can already notice some letters.
        FairRepair on YouTube
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3593
          • slovakia
          thanks mate. it is bearly wisible but it have marking SR209. but i find only SR2C4. do u think it is interchangable?
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            it's available on aliexpress
            edit: it's the same as sr2c9 as one seller has both code in the list on aliexpress
            • DynaxSC
              Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
              by DynaxSC
              Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
              For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
              06-10-2023, 11:30 AM
            • cmlewis89
              LG 47LB5DF blown power supply board
              by cmlewis89
              Hi folks,
              I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
              09-03-2024, 07:50 PM
            • Günter Schuch
              searching for Schematics & Boardview for Clevo P641HK1
              by Günter Schuch
              hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
              Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
              05-14-2025, 06:34 AM
            • peterwang
              CLEVO PCB:6-71-V2500-D02
              by peterwang
              Hi! I encountered a Clevo brand laptop that needed its boot LOGO modified. I found the LOGO address, but after the modification, the machine stopped displaying it. I'm puzzled. It worked normally before the 11th generation of CPUs, but it stopped working from the 12th generation onwards! The LOGO addresses are:
              166BACEC-6793-4F38-213F-DE0BEF4FEF95
              166BACEC-6793-4F38-213F-DE0BEF4FEF97
              166BACEC-6793-4F38-213F-DE0BEF4FEF99
              I have provided the BIOS and LOGO files that require LOGO modification, and I hope someone can help me.
              post moved...next time look for a thread...
              07-05-2025, 03:57 AM
            • drscoot
              HP X360 convertible battery blown fuse error, not charging
              by drscoot
              HP Modelnumber: 14-dh0061nb​
              This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
              The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
              I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
              And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
              All these 3 batteries are charging...
              12-15-2023, 05:54 AM
