HP LA-A994P no 3=5valw
  • ziko07
    • Jun 2021
    • 99
    • Somewhere
    Hi
    3valw rail has 10 Ohms only
    1v0 rail has 1 Ohm
    LDO 3 abd 5 present, byt not receive EC_ON from IO chip.
    When I bring 3v to enable pin I get all always rails but draws 350mA ...
    Any tips?
  • Sephir0th
    • Oct 2020
    • 1289
    Re: HP LA-A994P no 3=5valw
    Shorted PCH
    FairRepair on YouTube
    • ziko07
      • Jun 2021
      • 99
      • Somewhere
      And that why no enable signal from IO chip?
      +1 subscriber on YouTube
      Tnx
      • Sephir0th
        • Oct 2020
        • 1289
        Thx. Not exactly sure about the EC_ON signal. Can be some kind of protection triggered or the controller has simply died. Either way, 3.3V and 1.05V in short is worst case scenario.
        • BC_TechForum_drb
          Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
          by BC_TechForum_drb
          Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
          Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
          Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
          2/ Figure 1 Gfx-D500-B Front Facing
          3/ Figure 2 +5v supply (zoom-in)
          Intro:
          While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
          12-07-2023, 09:55 PM
        • Nagy Daniel
          Lowest possible resistance on laptop motherboard rail - Guide Table request
          by Nagy Daniel
          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
          So, I generated a table with AI so I can...
          03-04-2025, 08:24 AM
        • Victor Moreira Silva
          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
          by Victor Moreira Silva
          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
          Well, my decice specs are the following:
          Model: Acer Nitro 5 AN517-54-55T5
          CPU: Intel Core i5-11400H
          GPU: NVIDIA GeForce GTX 1650
          Motherboard: GH51G LA-L181P Rev:1c
          The symptom:
          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
          05-26-2025, 10:49 AM
        • lefetylorant
          Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
          by lefetylorant
          Hello Everyone,
          Long story short, I got this unit for very cheap.
          I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
          I've performed some measurements:
          - 20V rail perfectly...
          09-14-2023, 05:05 AM
        • bimole
          Weird behavior on 3.3V rail of a CORSAIR CX600
          by bimole
          A colleague gave me an apparently ill CORSAIR CX600.
          He told me that he heard a banging noise, and smelt the magic smoke.
          After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
          I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
          It's another story on the 3.3V rail...
          I have some devices to test deeply PSUs (scope, AC source, electronic load)...
          02-13-2025, 04:49 AM
