HP 15-eh1000 DAG7HAMB8F0 liquid damage
  • gs84
    • Dec 2022
    • 36
    • Ukraine
    Anybody can do the picture of MB damage side?
    • 21841
    Re: HP 15-eh1000 DAG7HAMB8F0 liquid damage
    This boardview and schematic might help -> https://www.badcaps.net/forum/showpo...80&postcount=2
    • gs84
      • Dec 2022
      • 36
      • Ukraine
      Thanks! And I found the picture of DAG7HAMB8E0 which is the same
      • Tomaty993
        • Jul 2024
        • 5
        • Madagascar
        Can i repair my DAG7HAMB8FO REV:F with it?
        The damaged part is there
        • m1ch43lzm
          • Mar 2019
          • 894
          • Peru
          Hi Tomaty993
          Which part is damaged? i have the same working board DAG7HAMB8F0 REV.F​. Can you draw a circle on the damaged part?
          • m1ch43lzm
            • Mar 2019
            • 894
            • Peru
            I have taken a picture of my board, could you compare with mine? Looks like a screwdriver slipped on your board Tomaty993
            EDIT: Just noticed the post date, last post was 2 months ago, I'm leaving the picture in case someone needs it
            Board is from HP 15-eh0010la ( 15-eh0xxx ) with Ryzen 7 4700u CPU
            • rounin
              MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
              by rounin
              Device Information
              • Model: MacBook Pro 14” M1 Pro (A2442)
              • Logic board number: 820-02443-05
              Original Issue
              The device suffered liquid damage, causing a short circuit on the logic board.
              Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
              Work Performed
              Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
              Current Status
              • When powered on, the screen shows support.apple.com/mac/restore....
              10-20-2025, 11:15 PM
            • mon2
              A1466 Macbook Air (Liquid damage repair)
              by mon2
              Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
              Macbook AIR Model A1466 Diagnostic 09-01-2021
              Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
              Problems & Resolutions
              1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
              09-01-2021, 09:31 AM
            • rilley
              MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
              by rilley
              I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
              I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
              My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
              And the resistor L4004 is literally burned.
              From what I see from the schematics, it does not affect any other rails, only the connection to the display...
              07-10-2024, 01:57 AM
            • Jenzo
              MacBook A1989 overheating after liquid damage
              by Jenzo
              Hey everyone,
              Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
              I can't figure out how...
              05-13-2023, 07:58 AM
            • mitchw
              MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
              by mitchw
              Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
              It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
              I quickly took it apart and washed the liquid residue off the mainboard.
              The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
              The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
              Now the laptop...
              07-16-2025, 07:55 AM
