Quanta G34A Big Trouble
  • sonunigam
    • Aug 2013
    • 151
    • Pakistan
    Hey Guys,
    I'm facing a very mysterious Problem, I've got a Motherboard Quanta G34A Which cannot be turned on with charger but it can be turned on with battery. when i connect a faulty but Original battery Laptop Turned on with charger. I've checked all Charging IC PU1 (ISL88750) Voltages, Everything is perfect but when i checked 3/5V Coils there is no voltages. I've checked VIN voltages on PU2 (SY8208B) for 3V IC that is only 8,7 VOlts. So i think VIN is not generating properly. I think VIN should be 19V. Anybody can give me any idea what should i do? I'm uploading Schematic Diagram n BoardView. Please Guys help me out.
    Thnx.
    1 Thing more on CLR (PR2) there're Proper 19V Generating. Which Means PQ1 and PQ2 Working well. ON PQ1 n PQ2 Gate Voltages 25Volts.
    MOD EDIT: Link to schematic -> https://www.badcaps.net/forum/showthread.php?t=66810
    Reminder: rules and organization of this section -> https://www.badcaps.net/forum/showthread.php?t=117483
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Quanta G34A Big Trouble
    NVDC technology is used and hence 8.8V as VIN may be absolutely fine.If its not turning on with charger only,check AD_ID.
    • sonunigam
      • Aug 2013
      • 151
      • Pakistan
      Hey mcplslg123,
      Thanks for your reply, But as i written in this thread that Laptop is turning on with battery but not with charger. Can you suggest anything? When i plug in the charger the charging light Glowing but Laptop is not turning on. When i checked 3v/5v Supplies. Those're not present there.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        You need to re-read my post#2 and act on that suggestion. I've read your post#1 and accordingly i do know it works on battery but dont on charger.
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • flat-earther
          how to prevent a connected charger from draining battery when not charging?
          by flat-earther
          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
          So the battery is backfeeding the charger and being drained.
          How can I prevent...
          08-07-2025, 01:04 PM
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • Johndill
          Dell Inspiron 7567 LA-D993P odd charger issue
          by Johndill
          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
          Here are the tested scenarios:
          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
          2. With the laptop off, plug in charger (LED says on) & the front charging...
          11-16-2022, 10:55 PM
        • Capacitorial
          Powersupply has all the voltages - Monitor still no power
          by Capacitorial
          Hello guys,
          I have a Philips 240B7QPJEB. The monitor seems completely dead.
          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
          The weird thing is, that the Power LED is powered over the TCON board.
          On The TCON...
          12-28-2024, 02:12 PM
