Lenovo Yoga 7i blown USB port issue
  • mon2
    • Dec 2019
    • 14659
    Re: Lenovo Yoga 7i blown USB port issue
    Suspecting that a high current / heavy drain USB device caused this load switch to fail. Perhaps one of the low current widgets advertised on TV like a USB car starter, coffee maker, back massager. Need to review the details of this component but yes, some monitor the D+/D- pins to determine how to charge the attached USB device. There is a whole specification on this topic alone. Each permutation defines different output current and/or voltage for the USB vbus line.
    If interested, purchase a replacement to restore this USB port. Before doing this, as suggested above, check the resistance to ground of the vbus pin. I think it will be ok unless the USB connector is damaged and shorting.
    • Rolin
      • Apr 2007
      • 174
      "Did anyone here took a closer look to the power rail, so USB_VCCA itself? Resistance ton GND measurement?"
      Checked UI2 Pin 12 (+USB_VCCA) a few times. Mostly get no continuity (autorange: OL on meter).. but sometimes did get around 5 M OHMs and climbing reading.
      • Rolin
        • Apr 2007
        • 174
        Mon2, I was told the owner did charge or power something in one of the ports - I suspected this as well because I've seen more than a few laptops come in for this reason. People should probably consider using a $10 adapter instead of their $1000 laptop - some laptop motherboards can be expensive!
        You mentioned to purchase a replacement to restore the USB port - are you referring to the TPS2546 (boardview shows SN1702001RTER)? That has been replaced (but currently removed for testing). Sorry if I'm misunderstanding...
        • Sephir0th
          • Oct 2020
          • 1289
          Time to check the differential pairs, not only on Port-side but also on PCH side. Then there is still a fpc-cable and a Sub-Board to rule out.
          Also it wasn't any single picture shared so far. Neither from UI2 with surrounding components, nor of the fpc-cable, the subboard, and the USB-Port itself.
          Last but not least I have a issue with your replacement. The Top marking between a SN1702001RTER and TPS2546 differ so it can be still the case that this part is the origin of your issue.
          It is not easy to assist like that.
          FairRepair on YouTube
          • mon2
            • Dec 2019
            • 14659
            The c2546 by TI is cited in the search engine under the alias of the other part number. Appears to be a jelly bean USB current limited and BC1.2 charger IC.
            New Original SN1702001RTER printing C2546 2546 WQFN-16
            https://a.aliexpress.com/_mrW1Eek
            Can you post pics of the PCB pads without the IC where this chip was soldered?
            Then again with the ic placed on the PCB pads. Do not solder it back but place onto the pads. Just wanting to confirm that pin #1 on the ic was aligned with pin #1 on the PCB pads.
            Would you still have the original SN1702001RTER part that was on this board? If yes, post a pic of this original part with the bottom side pads of the ic pins showing to allow for a review.
            • Rolin
              • Apr 2007
              • 174
              Thanks Mon2 and Sephir0th for your suggestions. I'll upload the pictures in my next post,
              As I mentioned, I'm not experienced at component level repair like this. But Mon2, you brought up a good thing to check - where is PIN1 on both the new and original chip? I soldered the new chip with the label on the chip pointing in the same direction as the original one - that appears to be a rookie mistake. Comparing both the new, I find the ground plate on the bottom has a corner missing indicating PIN1. But the missing corner on both the original and new chip do not match! So I now understand I installed the new chip with the wrong orientation.
              Here's what's confusing: I have the same identical problem with the old chip (correct orientation) and the new chip (wrong orientation) - 1 of the USB ports not working and constant errors in Windows related to surges on the USB port. But when the chip is removed, the errors are gone.
              Should I install the 2546 chip with the correct PIN1 alignment and see what happens? Or am I correct there is still some kind of problem elsewhere?
              • Rolin
                • Apr 2007
                • 174
                Here are the requested pictures:
                1) Original and new chip side by side - top and bottom. (see my previous post - Chip label orientation and ground plate corner indicating Pin1 are different between both chips)
                2) Original chip installed on the motherboard
                3) both sides of the motherboard.
                4) Picture of area with the chip removed
                • Sephir0th
                  • Oct 2020
                  • 1289
                  See what magic can happen just from a few pictures shared.
                  Install the IC with the correct orientation. If still not working you need to order a replacement to rule out you have burned the IC by this mistake. And from there we can proceed then.
                  • Rolin
                    • Apr 2007
                    • 174
                    Sephir0th, When I ordered the chip from Digikey, I ordered 2 - so I have a spare. I'll solder a new (untouched) chip properly aligned to Pin1. I'll let you know how it goes!
                    • Rolin
                      • Apr 2007
                      • 174
                      Mon2 and Sephir0th, I truly appreciate your help and patience with me on this. In the end, it was my own mistake that caused this thread to continue needlessly.
                      I soldered the new TPS2546 correctly aligned to PIN1 this time (now that I know to check the ground plate on bottom of chip indicating PIN1). Everything works now - no more USB errors and all 4 ports work again - including the bad port from the original problem.
                      Again, I can't thank you both enough!
                      • lordmmx
                        K6 Computers
                        • Apr 2015
                        • 48
                        • Slovakia
                        #31
                        Hey guys, I have same laptop with different issue: Only USB A port does not work and laptop shows overcharge/overvoltage on port and disables it. Otherwise laptop works well, charges, on charging USB C port on both sides, also both USB C work as normal. Only USB A does not work - port itself looks brand new - it is located on daughter board and connected via cable - when I disconnected the cable, error dissapeared. Any ideas?
                        • mon2
                          • Dec 2019
                          • 14659
                          Share pics of the parts on the cable. You should see a 5 or 6 legged part in a SOT23-5 or SOT23-6 package. This is a USB load switch. Suspecting this part to be defective and raising the excessive current trip. Another possibility is a similar looking packaged part that is a USB TVS ESD array. Once they trip, same fault will be raised.
                          • lordmmx
                            K6 Computers
                            • Apr 2015
                            • 48
                            • Slovakia
                            #33
                            This is the whole thing. That one chip looks blown
                            • mon2
                              • Dec 2019
                              • 14659
                              Yup. It needs to be replaced.
                              https://www.fortuneadvanced.com/prod...il/FA3210-i.13
                              https://www.aliexpress.com/w/wholesa....home.search.0
                              • lordmmx
                                K6 Computers
                                • Apr 2015
                                • 48
                                • Slovakia
                                #35
                                can I use TPS2546​ as a replacement? because I have them on hand readily availab.e
                                • mon2
                                  • Dec 2019
                                  • 14659
                                  Ok. This one was fun.
                                  Unable to locate the schematics in my database so searched for 'FA3210' and found this webpage:
                                  FA3210, USB Charging Controller and Power Switch with Load Detection, MQFN3x3mm2-16L, USB 3.0 port source controller of Lenovo YOGA 7 14ITL5 - Total Electronics
                                  This webpage notes the part is used on 'Lenovo YOGA 7 14ITL5' -> have a schematic for this one and schematic references indeed, the 'TPS2546'.
                                  Summary: Should be ok to use the TPS2546 here. Update this thread with your progress.
                                  • lordmmx
                                    K6 Computers
                                    • Apr 2015
                                    • 48
                                    • Slovakia
                                    #37
                                    Well... Maybe i did something wrong, or fault is somewhere else but, it runs insanelly hot and now it does not say overvoltage but unknown usb descriptor.
                                    I have installed the TPS2546 chip. I have few more so i'll try swapping them
                                    • mon2
                                      • Dec 2019
                                      • 14659
                                      Post a pic of this replacement part on the board.
                                      • lordmmx
                                        K6 Computers
                                        • Apr 2015
                                        • 48
                                        • Slovakia
                                        #39
                                        Damn, i just noticed... I dropped it in wrong way
                                        • mon2
                                          • Dec 2019
                                          • 14659
                                          Yes. Rinse & repeat.
                                          • ZixuTech
                                            Lenovo Yoga 330 11IGM YOGA330_MB_V06 Blown Voltage Reg V3P3A and ENE KBD Controller
                                            by ZixuTech
                                            This is a Data Recovery case from Lenovo Yoga 330 11IGM onboard eMMC Sandisk 128GB
                                            Seems like the device had a power surge. Blown U6002 and went and cracked the die of the KBD controller. I detached the JP6003/4 tracks around U6002 but short still appears around the kbd controller (i believe)
                                            I havent had a case to replace and reprogram KBD controllers before. How can I get the dump and what tool do I need to use. Is there a process written somewhere? Thanks in advance.
                                            Let me know if you know any jigs which can recognise these sandisk chips. I wont mind...
                                            01-01-2024, 10:15 PM
                                          • rounin
                                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                            by rounin
                                            🛠 Original Issue
                                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                            04-19-2025, 01:18 AM
                                            Lenovo Yoga C930 Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                            This specification for the Lenovo Yoga C930 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C930 boardview and C930 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo Yoga...
                                            09-06-2024, 02:34 PM
                                            09-06-2024, 08:41 AM
                                            09-06-2024, 07:30 AM
