A2289 screen, used vs oem
  • Max89
    • Apr 2023
    Need an opinion here please.
    To replace an A2289 MacBook screen do you recommend a used screen or OEM?
    They are pretty much the same price.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
