toshiba c850d black screen
  • mo000
    • Nov 2017
    • 276
    • algeria
    hi
    Toshiba C850D PLABX CSABX UMA DSC rev 2.1
    builtin amd cpu
    chipset amd
    turning on with black screen and 0.9 amps consumption
    all the voltages needed are present
    i try flash bios with different files but same result
    i suspect in cpu or chipset .
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: toshiba c850d black screen
    Consumption on dc supply(after turning on)
    01.With Ram stick
    02.Without ram stick?
    • mo000
      • Nov 2017
      • 276
      • algeria
      01.With Ram stick
      almost a same consumption .
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        That does mean ram is not read . Do check ram requirements,flash known good clean me bios as first steps.
        • mo000
          • Nov 2017
          • 276
          • algeria
          but i have ram voltage 1.5v and vtt 0.75
          can you clean to me the origin dump .
          i can't fine any schematic for this model just a boardview .
          Last edited by SMDFlea; 05-27-2023, 04:06 PM. Reason: Bios removed,this isn`t the bios requests section...
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            I think this one is amd apu-so no me region here.Its not enough to have 1.5V/0.75V for ram to work. One needs to check whether communication is there on SDA/SCL pins and Ram is being reset or not. You need a scope to check the communication.
            • mo000
              • Nov 2017
              • 276
              • algeria
              yes the cpu is amd apu
              i check and found all ram requirements
              VDD SPD = 3.3V
              SDA/SCL =3.3v
              DRAM_RST# = 1.5V
              also i try a different ram and same result .
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Link the boardview here. have you checked ram slots full requirement? there should be a 3leg or 6 leg mosfet between FCH and ram slot for SDA/SCL communication. So there should be 2 such mosfets and take a close look on them.
                • mo000
                  • Nov 2017
                  • 276
                  • algeria
                  according to the boardview SDA/SCL connection between fch and ram slot is direct no mosfets .
                  i think i check all requirements
                  VRef_DQ
                  VTT
                  VRef_CA
                  VDD SPD
                  SDA data
                  SCL clock
                  DRAM_RST#
                  all are ok nothing missing .
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    https://www.badcaps.net/forum/showthread.php?t=117483
                    If you request/offer BIOS/schematics/boardviews, please post in the appropriate subsection, and you can link to it in the troubleshooting topic.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Yes,asper bdv nothing is inbetween ram slot /FCH wrt SMBUS comminication. Seems like FCH issue but cant say with 100% certainity without measurement pics on SDA/SCL/Dramrst# on scope.
                      • mo000
                        • Nov 2017
                        • 276
                        • algeria
                        yes i think so
                        from ram slot under the scope
                        sda on pin 200 =3.3v
                        scl on pin 202 = 3.3
                        dramrt on pin 30 = 1.5
                        i think i get the right reading .
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Originally posted by mo000
                          yes i think so
                          These voltages are correct but that doesnt proves there is communication. That can be only confirmed by oscilloscope where you can observe the pulses.
                          • mo000
                            • Nov 2017
                            • 276
                            • algeria
                            These voltages are correct but that doesn't proves there is communication. That can be only confirmed by oscilloscope where you can observe the pulses.
                            yes i know but unfortunately i don't have oscilloscope .
                            • mon2
                              • Dec 2019
                              • 14118
                              If you power up without the ram, does the logic board send out the missing ram beep pattern?
                              • mo000
                                • Nov 2017
                                • 276
                                • algeria
                                no
                                • HTR-Informatique
                                  by HTR-Informatique
                                  02-09-2025, 06:51 AM
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                • VcemPzd
                                  Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                  by VcemPzd
                                  Hello everyone !
                                  My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                  04-28-2025, 10:14 AM
                                • DaniK
                                  Acer Aspire E5-574-52RH - black screen
                                  by DaniK
                                  I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                  Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                  Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                  Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                  The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                  Symptoms are:
                                  - random black screen after displaying Acer logo...
                                  02-21-2024, 06:27 AM
                                • turmix
                                  AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                  by turmix
                                  Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                  The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                  At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                  During another reassembly, I made a mistake, and...
                                  01-29-2024, 03:48 AM
