Dell E6410 restart issue
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    (Dell E6410 LA-5471P
    Restarting issue.)
    On sio pin no. B35, +3.3V_ALW is unstable (dropping) whenever restarted, the atrange thing all other pins have stable +3.3V_ALW (although they are all connected) ,.,,, what's the science is this..., any guide please
  • mon2
    • Dec 2019
    • 14662
    Re: Dell E6410 restart issue
    Remove all power and check the resistance to ground of this power rail.
    Also check the resistance from this point at the sio pin and where this rail starts at the regulator.
    What are the measurements?
    • SuperJames
      Dell G3 17 3779 Weird power cycling and shutdown/restart issue
      by SuperJames
      This one's a weird one, and still unsolved despite it having gone back to Dell once.
      Specs
      i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
      Backstory
      I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
      10-23-2023, 04:09 PM
    • Ven
      Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
      by Ven
      Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
      Issue Description:
      1. CPU Overheating to 100°C
        • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
        • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
        • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
        • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
        • Thermal
      02-12-2025, 03:57 PM
    • NotEnough
      Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
      by NotEnough
      I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
      What I've Tried So Far:
      • Reseated the cables.
      • Reinstalled AWCC and AlienFX services.
      • Attempted BIOS downgrade but no improvement.
      • Inspected ribbon cables for damage.
      • Explored the possibility of BIOS or
      10-19-2024, 01:34 AM
    • computerbacon79
      Dell Inspiron 3480 All in One corrupt Bios issue
      by computerbacon79
      The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
      05-06-2025, 06:43 PM
    • D3D_Tray
      Dell Latitude 5320 USB-C port issue
      by D3D_Tray
      Hey guys,
      so my half-year out of warranty Dell Latitiude 5320 (19817-1 SOUTH PEAK 13 10L) w/ i5-1145G7 and 16GB just started to act weirdly...
      The first/upper USB-C/TB port suddenly didn't accepted the charger every time and sometimes only a different one... or with a different cable but so far, the self-diagnostics didn't noticed anything so I suspected a dirty port.
      Today however... it stopped completely to accept a charger, the second/bottom one however does and after a half an hour, I notice something getting hot under there... blazing hot!
      04-24-2025, 10:27 AM
