help! macbook a2442 / 820-02098 does not turn on
  • marcelofct
    • May 2019
    • 122
    • chile
    Hello friends, I have this mac 820-02098 to which liquid spilled, I cleaned it and checking it is short-circuited, I do not have a green or orange light, PP3V8_AON is short-circuited, change capacitors and even so, it is still short-circuited, please help me to fix the macbook ,
    these voltages I have
    PPDCIN_AON : 5v
    PPBUS_AON : 12.2v
    PP3v8_AON_VDDMAIN :0v
  • mon2
    • Dec 2019
    • 14010
    Re: help! macbook a2442 / 820-02098 does not turn on
    Remove all power.
    Meter in resistance mode.
    What is the exact resistance to ground of PP3v8_AON_VDDMAIN ?
    • marcelofct
      • May 2019
      • 122
      • chile
      Originally posted by mon2
      Remove all power.
      PP3v8_AON_VDDMAIN 0.5 ohms
      PP3v8_AON = 0.5ohms
      • mon2
        • Dec 2019
        • 14010
        You have a short on this line. Check for any defective looking parts like capacitors.
        Do you have an adjustable power supply that can support 1 volt output?
        • marcelofct
          • May 2019
          • 122
          • chile
          yes, I have one, I tried to inject 1v but nothing is hot, it consumes 5 amps, what do you think it could be, I changed some capacitors and it's still the same, I look forward to your help
          • mon2
            • Dec 2019
            • 14010
            Would you have a heatsink on the CPU? If yes, remove it to check if the CPU is heating up or not.
            • marcelofct
              • May 2019
              • 122
              • chile
              I inject 1v and nothing, cpu cold like a stone, I have looked at the motherboard and I can't find discolorations or broken capacitors, what do you recommend to continue doing?
              • mon2
                • Dec 2019
                • 14010
                Consider to increase the current if possible on your power supply. If it is not possible, increase the voltage.
                A key concern is if the high side CPU power rail is shorted with this one. This is the reason to keep the voltage as low as possible but increase the current.
                Our short killer which claims to support peak current of 30A will often find offenders at 5-8A. Usually a bad ceramic and/or tantalum capacitor. They crumble under the current using 0v8 or 1v0 setting.
                • marcelofct
                  • May 2019
                  • 122
                  • chile
                  I have a power supply up to 10a
                  from what I see the short circuit is not related to the cpu
                  I leave you an image of the sector
                  • mon2
                    • Dec 2019
                    • 14010
                    Ok, crank up the current setting till someone cries uncle. You can apply IPA (alcohol) to see who is heating up. The heat will cause the IPA to mist or evaporate quickly.
                    • marcelofct
                      • May 2019
                      • 122
                      • chile
                      I got to 8.5a and didn't notice anything , do you think I should remove the capacitors that were with that leak and discard that sector?
                      • mon2
                        • Dec 2019
                        • 14010
                        To confirm, the power supply is reporting that the rail is consuming 8.5A ?
                        At this setting, someone has to be heating up. Have you check both sides of the PCB?
                        • marcelofct
                          • May 2019
                          • 122
                          • chile
                          I'll continue tomorrow, it's time to go home. I'll let you know tomorrow, thanks for your help.
                          • marcelofct
                            • May 2019
                            • 122
                            • chile
                            I still can't find the shorted component, I've tried isopropyl alcohol and nothing, am I doing something wrong?
                            I inject voltage into a capacitor where the short is and nothing gets hot,
                            • dbuergi
                              Macbook A2442 no display board 820-02098
                              by dbuergi
                              i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
                              So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
                              05-25-2025, 10:58 AM
                            • TechSplendid
                              MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
                              by TechSplendid
                              Hi All,
                              I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
                              Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
                              04-09-2025, 02:13 AM
                            • Constantinos
                              Macbook Pro A2442 820-02098 No image but has backlight
                              by Constantinos
                              Hi all
                              I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                              He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                              Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                              Obviously, he decided against this and gave it to me so that I could have a crack at it.
                              From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                              08-24-2024, 09:48 AM
                            • Enzo150i
                              MacBook A2442 exclamation mark after oxydation
                              by Enzo150i
                              I have a MacBook Pro A2442 with board 820-02098-A very highly oxydated (water) by an accident.
                              The customer just need to recover the data (no backups, heh), so we cleaned fully to make it power on.
                              Fortunately the Mac is still alive but it shows an exclamation mark in a circle (!) (Apple T2 fw issue?) with the text "support.apple.com/mac/restore" and doesn't go further.
                              We tried to interface with another Mac, but can't get in DFU. Very likely the keyboard is gone too because the water, so we're planning to buy a cheap compatible one just to....
                              06-29-2025, 01:26 PM
                            • veedo
                              Macbook A2442 820-02098 boot and display issue
                              by veedo
                              Hi All
                              I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
                              Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
                              I found component UD290 ( SF0101-I2C) little...
                              04-01-2024, 06:06 AM
