Lenovo 330-15ich dead
  • Kitayu
    • Oct 2021
    • 22
    • Turkey
    Re: Lenovo 330-15ich dead
    I inserted the chip and got something like this:
    The computer is now powered, when I press the power button, high and low frequency sounds are heard sequentially from the processor.
    Also, when I press the power button, the led next to the charging socket blinks in sync with the sound of the processor.
    • Kitayu
      • Oct 2021
      • 22
      • Turkey
      When I put the battery, the device turns on but I can't get a display..
      • mon2
        • Dec 2019
        • 13859
        Is the ram removeable on this model? If yes, remove it and check if it complains with a POST beep tone pattern to note that the ram is missing.
        • Kitayu
          • Oct 2021
          • 22
          • Turkey
          Hello
          I realized later that the problem is as follows:
          When I insert the battery into the computer, the battery first draws 0.20 amps, after 3 seconds it starts to draw 1 amper
          I thought the charging current was the computer's stolen current because the starting current was lit
          Later, I realized that when I actually press the on key, only the start LED lights up, but the system does not turn on. So it probably needs to be programmed ec, as the respondent said beforehand
          There is someone on Youtube who manages to program without a programming device, with only a simple eprom programmer, but our io chip is not the same
          How to program this io chip with a bios programmer
          Note: the bios programmer I have is a sofi branded mid-range programmer (I don't remember the model), but it is a device that I can program by selecting the model written on the chip from the interface and programming
          (I don't think my eprom programmer has an IO chip in its interface)
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            If the EC was from same board, then it does not need programming(Unless the firmware in the donor ec is also corrupt). You need a dedicated SIO programmer like SVOD etc to do this job.
            • Kitayu
              • Oct 2021
              • 22
              • Turkey
              #26
              No, the ec is not from the same card, it is not a different version of the card I have, the computer I am taking the ec from is a few sub-models of the one I have, and the cards are completely different.
              So I think the ec in io doesn't match, it's like removing an ec bios chip from a different motherboard and plugging it into my own motherboard.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                Yes, In the current case, EC needs programming as donor/receiver are not exact same board.
                • Kitayu
                  • Oct 2021
                  • 22
                  • Turkey
                  #28
                  Yes, it is certain that it should, but I don't have an io chip programmer. Not in a place I know. How am I going to program this?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    #29
                    I'm sorry but you need a sio programmer and there is no other option. Check if pre-programmed sio is available in your location or not(Unfortunately we dont have such an option in India). Else, try locating a repair workshop who have the necessary tools to do the job.
                    • Nagyesz
                      Lenovo ideapad 330ICH - Dead, no volts on coils
                      by Nagyesz
                      Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
                      I've never encountered something like this before;
                      No charging light, full dead
                      Lenovo Ideapad 330-17ICH
                      • PL3102: 5 ohms
                      • PL3001: 3.2 ohms
                      • PL3101: 2 ohms
                      • PL5801: 3.5 ohms
                      • PL5501: 270 ohms
                      • PL701: 35 ohms
                      • PL501: 146 ohms
                      • PL503: 390 ohms
                      • PL402: OL (0.27V) +5VALW_P
                      • PL301: OL
                      • PL401: OL (0.03V) +3VALW_P
                      + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
                      10-11-2024, 10:12 AM
                    • Zmay2509
                      Lenovo T14 nm-c931 1th gen intel 10th DEAD
                      by Zmay2509
                      Hi, I have dead t14 gen1 with nm-c931 motherboard.
                      Laptop doesn't turn on and does not show any sings of life.(battery is completely flat, do I need it for power on??)
                      When I connect usb c power adapter it draws 0.02A at 20v, I get voltage 20.5V up to 2nd mosfet and nothing out (PQ0006 before current resistor and buck-boost) when I touch gate pin of PQ0006 with tweezers it opens and I get 20.5v on current resistor;
                      But even with that "trick" I cant get laptop to turn on, that's probably because BQ25700ARSNR is not happy and not making VSYS15 rail.
                      03-25-2025, 02:44 PM
                    • madan1
                      Lenovo Ideapad S130 is the CPU dead?
                      by madan1
                      Good day.
                      I'm trying to figure out what's wrong with a Lenovo Ideapad S130 motherboard. When I connect it to the bench PSU and limit the supply to ~2.2A (about the limit of the lenovo stock PSU), the board absorbs all the amperage and the voltage on the PSU drops down to about 4-5V.
                      The components on the board that get hot are the two mosfets ( 1 and 2 on the photo ) and the CPU. The resistance to ground measured on the power rail coils can be seen on the image (~17 and ~50 ohms). On the top of the CPU there are few caps which measure dead short. I checked all caps on the top side...
                      03-14-2024, 09:14 AM
                    • reformatt
                      Lenovo NM-A921 (Yoga 900-13ISK2) dead
                      by reformatt
                      This machine has been in a few times with an intermittent fault of not charging. Motherboard is NM-A921 (https://www.badcaps.net/filedata/fetch?id=2051581)
                      So back again now, not working at all. Previously the adaptor had been replaced along with the DC charge port. This is one of these trapezoid shaped orange USB ports that Lenovo were using prior to going USB-C. It has 4 pins, but the DC connector jack on the PCB has 5 pins.
                      Fault presentation was the adaptor is only producing 5.2V, not 20V and this isn't reaching the input of the NVDC charger (PQ5/PQ6). There are 5...
                      02-05-2025, 05:24 PM
                    • angel-boy
                      Lenovo M70Q - 11E8 - that is dead
                      by angel-boy
                      hy, i have a PC M70Q - 11E8, that is dead, no power led, no logo led , change the CPU, still dead !
                      - pc is like new but with OS amazon.Gringotts2, i try to program bios 16mb, nothing, i change the 16mb W25Q128 with other, write another dump file, still no power up, replace again W25Q128 with other and write another dump file, still DEAD
                      - i have 3v3, 5v, 1v and others voltage. power botton drops to 0 and back 3v3.
                      my question , is possbile this pc will not power up becouse is locked ? maybe need a lan wake up , i dont know.​
                      03-29-2024, 07:21 AM
