Lenovo 330-15ich dead
  • Kitayu
    • Oct 2021
    • 22
    • Turkey
    Hi, this morning when measuring the input voltage of the device I am powering with the adjustable power supply, I accidentally short-circuit the signal pin with 19 and the device went silent
    How do I handle this? Is the processor damaged? When I looked at the datasheets, I saw that the signal pin did not go directly to important places, but the device does not work
    Mainboard : EG530 NM-B671
    I look forward to your very urgent help, thank you in advanceI look forward to your very urgent action, thank you in advance
  • mon2
    • 14662
    Re: Lenovo 330-15ich dead
    Which signal pin?
    Start with the main power rail review at the charger IC.
    Carefully, measure the voltage to ground of N2.
    Schematic is here:
    https://www.badcaps.net/forum/showthread.php?t=96270
    What is the voltage?
    • Kitayu
      • Oct 2021
      • 22
      • Turkey
      Originally posted by mon2
      Which signal pin?
      Schematic is here:
      I'm talking about the pin that tells me how many watts the adapter is
      Take voltage measurementI will look at the schematics you threw when I go to the workshop, the measurements I take now are as follows:
      19 volts goes healthy up to the mosfets, but the on key goes 1.5 - 2.0 volts, not 3 volts, but I'm not entirely sure because the on key is on the keyboard and I don't know which pin on the keyboard belongs to the on key. But all voltages are no more than 2 volts
      • Kitayu
        • Oct 2021
        • 22
        • Turkey
        Sorry for bad english, i used translate
        • Kitayu
          • Oct 2021
          • 22
          • Turkey
          Which signal pin?
          Schematic is here:
          Hello, I looked at your schematic, but it is the same as the schematic I have, exactly which pages do I need to look at?
          • mon2
            • 14662
            PU301, check the voltage to ground of:
            pin 1 (ACN)
            pin 2 (ACP)
            pin 3 (CMSRC)
            pin 4 (ACDRV)
            pin 5 (ACOK)
            pin 6 (ACDET)
            pin 24 (REGN)
            • JaroTech
              • Mar 2015
              • 351
              Hi, what voltages do you have on resistor PR109 on both sides?
              • Kitayu
                • Oct 2021
                • 22
                • Turkey
                pin 1 (ACN)
                pin 2 (ACP)
                pin 3 (CMSRC)
                pin 4 (ACDRV)
                pin 5 (ACOK)
                pin 6 (ACDET)
                pin 24 (REGN)
                sure
                pin 1 : 19v
                pin 2: 19v
                pin3: 19v
                pin4: 24.8v
                pin5: 0v
                pin6: 2.7v
                pin24: 18.7v
                • Kitayu
                  • Oct 2021
                  • 22
                  • Turkey
                  i cant find this
                  • Kitayu
                    • Oct 2021
                    • 22
                    • Turkey
                    pin 1 (ACN)
                    pin 2 (ACP)
                    pin 3 (CMSRC)
                    pin 4 (ACDRV)
                    pin 5 (ACOK)
                    pin 6 (ACDET)
                    pin 24 (REGN)
                    I don't understand what you mean by ground line. I fixed the negative probe to the ground and measured with the positive lead.
                    • Sephir0th
                      • Oct 2020
                      • 1289
                      If the middle pin was shorted with charger plus, at least the Embedded controller has blown up for sure. Time to look there, I'd say. Charging circuit looks absolutely fine ( ACOK could be missing because of a shorted +3VL ).
                      FairRepair on YouTube
                      • Kitayu
                        • Oct 2021
                        • 22
                        • Turkey
                        hello, can you tell me exactly where I should look with the name on the diagram?
                        note: when I take a measurement again, there is no data about 3 volts and 5 volts. there is only 19 volts
                        • reformatt
                          • Feb 2020
                          • 1496
                          ADAPTER_ID goes directly to the EC on pin 72. With PR109, it's supposed to form a voltage divider from +3VALW with a resistor in the charger. Therefore, pin 72 should never be exposed to anything above 3V.
                          There is a protection device PD102 but given your symptoms I'd agree with @Sephir0th and say you fried your EC. It's a flaw in Lenovo's designs, as a collapsed/shorting charge socket can do the same thing, and it usually results in a shorted EC.
                          • mon2
                            • 14662
                            pin24 (REGN): 18.7v
                            REGN = 18v7 ?? Confirm it is ~6 volts since your ACDRV makes sense to be ~25v.
                            But as per above, review your EC for damage.
                            • Kitayu
                              • Oct 2021
                              • 22
                              • Turkey
                              What exactly are we talking about when we say embedded controller?
                              • khaahk
                                • Dec 2013
                                • 812
                                • Estonia
                                Page 2 schematic shows block diagram. EC=embedded controller=IT8586E
                                • Kitayu
                                  • Oct 2021
                                  • 22
                                  • Turkey
                                  I see another small dot on the ec that is independent of its pointer point (in the middle) I guess that's a sign of blushing
                                  anyway i'll see if i have this, or i'll order it, but are there any measurements i need to take to make sure the ec is fully lit?
                                  • mon2
                                    • 14662
                                    You should post a clear picture of the EC for a review.
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Before ordering the new EC,keep it in mind that its need to be programmed.
                                      • Kitayu
                                        • Oct 2021
                                        • 22
                                        • Turkey
                                        I have a model of this computer without a graphics card and a round socket. Ec are the same. I'm going to use it, I only have the eeprom programmer in my hand, so I can't program it, would it be a problem?
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • Nagyesz
                                          Lenovo ideapad 330ICH - Dead, no volts on coils
                                          by Nagyesz
                                          Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
                                          I've never encountered something like this before;
                                          No charging light, full dead
                                          Lenovo Ideapad 330-17ICH
                                          • PL3102: 5 ohms
                                          • PL3001: 3.2 ohms
                                          • PL3101: 2 ohms
                                          • PL5801: 3.5 ohms
                                          • PL5501: 270 ohms
                                          • PL701: 35 ohms
                                          • PL501: 146 ohms
                                          • PL503: 390 ohms
                                          • PL402: OL (0.27V) +5VALW_P
                                          • PL301: OL
                                          • PL401: OL (0.03V) +3VALW_P
                                          + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
                                          10-11-2024, 10:12 AM
                                        • Zmay2509
                                          Lenovo T14 nm-c931 1th gen intel 10th DEAD
                                          by Zmay2509
                                          Hi, I have dead t14 gen1 with nm-c931 motherboard.
                                          Laptop doesn't turn on and does not show any sings of life.(battery is completely flat, do I need it for power on??)
                                          When I connect usb c power adapter it draws 0.02A at 20v, I get voltage 20.5V up to 2nd mosfet and nothing out (PQ0006 before current resistor and buck-boost) when I touch gate pin of PQ0006 with tweezers it opens and I get 20.5v on current resistor;
                                          But even with that "trick" I cant get laptop to turn on, that's probably because BQ25700ARSNR is not happy and not making VSYS15 rail.
                                          03-25-2025, 02:44 PM
                                        • reformatt
                                          Lenovo NM-A921 (Yoga 900-13ISK2) dead
                                          by reformatt
                                          This machine has been in a few times with an intermittent fault of not charging. Motherboard is NM-A921 (https://www.badcaps.net/filedata/fetch?id=2051581)
                                          So back again now, not working at all. Previously the adaptor had been replaced along with the DC charge port. This is one of these trapezoid shaped orange USB ports that Lenovo were using prior to going USB-C. It has 4 pins, but the DC connector jack on the PCB has 5 pins.
                                          Fault presentation was the adaptor is only producing 5.2V, not 20V and this isn't reaching the input of the NVDC charger (PQ5/PQ6). There are 5...
                                          02-05-2025, 05:24 PM
                                        • madan1
                                          Lenovo Ideapad S130 is the CPU dead?
                                          by madan1
                                          Good day.
                                          I'm trying to figure out what's wrong with a Lenovo Ideapad S130 motherboard. When I connect it to the bench PSU and limit the supply to ~2.2A (about the limit of the lenovo stock PSU), the board absorbs all the amperage and the voltage on the PSU drops down to about 4-5V.
                                          The components on the board that get hot are the two mosfets ( 1 and 2 on the photo ) and the CPU. The resistance to ground measured on the power rail coils can be seen on the image (~17 and ~50 ohms). On the top of the CPU there are few caps which measure dead short. I checked all caps on the top side...
                                          03-14-2024, 09:14 AM
