Lenovo Ideapad 3-15ITL6 NM-D471 NO POWER
  • Dana24
    • Jan 2022
    • 18
    • Netherlands
    Laptop is not turning on or any led is showing.
    PU5601 is getting untouchably hot changed it but still getting hot and no sign of live? what should i do next?
    PC5611 was also shorted changed the cap and the short was gone, but still no 3.3V on the cap wich should receive from the PU5601.
    PU5601 = SY8386BRHC_QFN16_2P5X2P5
    Schematic: https://www.badcaps.net/forum/showth...55#post1205455
    Last edited by Vesko356; 05-02-2023, 01:40 PM. Reason: Added link to the schematic.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo Ideapad 3-15ITL6 NM-D471 NO POWER
    PC5611 is a cap on +3V LDO. What is the resistance to GND on PC5611,pin1? Resistance should be measured without any power source .
    • Dana24
      • Jan 2022
      • 18
      • Netherlands
      I did somefurther diagnostics and think its IO chip. Ordered one when i receive it i will update this post.
      • Windows8RTMUser
        • Sep 2018
        • 15
        • Philippines
        Having the same issue with an NM-D472, led blinks for 12 times and occasionally when it stops blinking and pressing the power button 3v_alw becomes .8v while the enable pin for pu5601 is pulled low, pu5601 also gets hot because something is drawing too much current from 3VLP, so far I have replaced super io/ec and lv5116a and it has made no difference, I'm starting to think its a dead CPU/PCH but it seems to properly load the new ec firmware onto a blank ec, disconnecting 3v pch with a blank chip it doesn't program a blank ec
        3vlp is 130k ohm
        3v_alw is 9.2k ohm
        Bypassing the ldo and using a bench psu it draws 160ma from 3vlp when in the state that makes pu5601 hot
        • Dr.d
          Help please..Lenovo ideapad 5 14itl05 power and charging problem
          by Dr.d
          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
          04-05-2024, 11:48 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • rabsonnjala
          LENOVO IDEAPAD 100 works only on bench power supply
          by rabsonnjala
          Hie I have a Lenovo laptop
          Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
          it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
          below are my readings
          with the original charger only
          JBATT1
          PIN1 0.22V
          PIN2 0.22V
          PIN3 0.45V
          PIN4 0.45V
          PIN5 O.43V
          PIN6 0V
          PIN7 GND
          PIN8...
          11-20-2021, 08:32 AM
        • acata
          Lenovo Ideapad slim 3 not power on
          by acata
          Lenovo Ideapad slim 3 not power on after consumer problems is can not on after sleep mode.
          And the consumer asked for reinstalling OS.
          I reinstalled windows 10 and working fine. After i leave it for updating windows and goes to sleep mode. Now it cant draw any input from power supply.
          Motherboard number is GS450&GS550&GS750 MM-C821 REV: 1.0
          Check the main power rail for 20v input ok
          No amper input from Power supply 0.013a
          Mosfet PQ201 20v and 26v ok.
          3.3v exist
          1,8v exist
          5v exist
          12v from baterai exist....
          09-30-2024, 09:42 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
