MSI GS66 Stealth 11UE-007 | No power
  • Eniaro
    • Mar 2021
    • 76
    The history behind this PC is... it has passed through many hands trying to repair it
    The back story the screen was flickering and someone before me changed the screen, it apparently worked then went back to flickering then eventually stopped powering on.
    I used a thermal camera to find out what gets hot. The area registered 40+ °C simply by plugging in the charger. I used freeze spray to isolate, which lead to 1285B
    I do not have the schematics or board view but requested it
    I don't see any part physically damaged so far should I take the gamble and change it?
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: MSI GS66 Stealth 11UE-007 | No power
    What is the value in Ohms of the resistance to ground at VREG3, VREG5, SW1, SW2, VIN? Remove the power adapter and the battery before measurements.
    Become a Badcaps supporter
    Thanks to all supporters.
    • Eniaro
      • Mar 2021
      • 76
      VREG3 004.9 / 005.0 Ω
      VREG5 open
      SW1 open
      SW2 open
      VIN open
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        VREG5 open
        SW1 open
        SW2 open
        VIN open
        In short it's a bad news I'm afraid, 3.3V LDO line is in short, which in 99% of the cases means dead multi-controller.
        • Eniaro
          • Mar 2021
          • 76
          Are you saying replacing 1285B (TPS51285B) may bring it back to life or I should remove 1285B (TPS51285B) and look for shorts?
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Remove the chip and check again VREG3 line for short, I'm pretty sure you'll still have a short there, if that's the case you can inject 1V/1A to see if the SIO chip is shorted, if it is getting hot you must replace it.
            If you're lucky enough after removing the TPS51285B chip from the motherboard VREG3 line will not be shorted anymore which means TPS51285B is faulty and you must replace it, but the first scenario is most likely the case here - shorted SIO chip is the "usual suspect" in 99% of the cases as I already said.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Besides SIO, sometimes PCH part of SOC also gets shorted when +3V LDO is shorted to Ground.
              • Eniaro
                • Mar 2021
                • 76
                Pardon my noobness, I did not understand what SIO/multi-controller meant after looking it up I understood what to look for which led me to reinspect the board.
                ENE KB9548GF2 appears to be damaged
                In an attempt to find out more about this chip, I found another MSI model & a thread "MSI GE76 Raider 11UH Super I/O replacement" that uses the same ENE KB9548GF2 SIO and having similar issues
                • mon2
                  • Dec 2019
                  • 14177
                  100% damaged. This is a BGA packaged component.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    MSI Gaming GS66 Stealth 10SF-427FR Notebook GS Specification for Upgrade or Repair
                    This specification for the MSI Gaming GS66 Stealth 10SF-427FR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GS66 Stealth 10SF-427FR boardview and GS66 Stealth 10SF-427FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 08:10 PM
