DELL LATITUDE 5290(DDM60 LA-F391P) No display
  • andresi
    • Nov 2020
    • 152
    • INDONESIA
    so i have dell 5290 with code board LA-f391p, the problem is cant display, the capslock still on and blank screen no response. but when i try to remove the flexible lcd from the board is getting normal, capslock can response, i tried with external lcd its working. i check in lcd F1 got 3.3v and F2 13V i try with another lcd its working too, but if i try unplugging and plugging it a few times, it sometimes works, if i restart it it comes back like the problem in the beginning.
    so im want to ask,
    is the problem with the lcd?
    or anything else? with board of lcd?
    is confused me
  • andresi
    • Nov 2020
    • 152
    • INDONESIA
    Re: DELL LATITUDE 5290(DDM60 LA-F391P) No display
    i just bought the same motherboard and try to compare with the problem :
    the good motherboard have :
    -3.099v in disp_on
    -3.363v in DV2 pin2 (PANEL_BKLEN)
    the problem motherboard dont have volt in disp_on or dv2 pin2.
    i see in schema PANEL_BKLEN go straight to the cpu.
    i think the problem is solved now with change the motherboard haha
    or do have another solution?
