How USB-C charging works? Lenovo Yoga7
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello guys.
    As there are more and more USB-C charging laptops i want to ask if somebody know how to diagnose it or how it works.
    as example i have this Lenovo yoga 7 nm-D131 that not detect charger so charger voltage not goes up to 20V but stay at 5V and no current passing
  • mon2
    • 14663
    Re: How USB-C charging works? Lenovo Yoga7
    Power delivery is about single wire communication of the BMC pins (CCx) on the Type C connector.
    Often these pins / contacts get damaged due to cross shorts during pulling / insertion of the type C connector at an angle.
    Remove all power. Meter in diode mode.
    Red meter probe, yes red, to ground.
    Black meter probe to point to test.
    Check the diode readings of:
    TBTA_CC1
    TBTA_CC2
    TBTB_CC1
    TBTB_CC2
    The first point of contact from the outside world will be the power delivery controller onboard. This is often a stand alone device that negotiates the power delivery contract with the external power adapter. Be sure that the external power adapter is suitable to power the board (suggest 100W or higher). The adapter does not have to be the original but should be a known good one.
    We used the model from LVSUN for years (purchased it for $20 USD at the HK fair). Worked fine till some scum in California sold us a defective macbook logic board with pulled parts and BGA shorts. Ebay refunded the entire purchase but it killed our power adapter.
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • nikolayu
      Lenovo ThinkPad X1 Nano Gen 1 not charging on 1 USBC
      by nikolayu
      I have Lenovo ThinkPad X1 Nano Gen 1 which is not charging on 1 usbc port (the one that has mark for charging).
      When i connect usb it switchs to 20v but no current draw (only 0.02a) and orang light is on. In windows it shows that is charging but percentage is dropping.
      Other usbc is charging fine,
      I installed lates bios and firmwares for thunderbolt and battery.
      Could be faulty JHL8040R controller?
      08-31-2024, 11:08 AM
    • thesame
      Lenovo TB-X605F fake charging after charging connector replacement.
      by thesame
      Hy guys, i have this lenovo TB-X605F with charging problem, the tablet is fake charging, i have replaced the charging connector twice, it only draws 0.40 Amps when pluging the cable for the first time then it stops drawing any Amps but the tablet keeps showing the charging image at 0% as long as i keep it connected. I have no voltage at the battery connector with the cable pluged, but i have 5 volts after usb connector on some testing points on the board.
      04-03-2024, 03:14 AM
    • Grucha98
      Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
      by Grucha98
      Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
      Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
      09-09-2024, 11:22 AM
    • B2L_Repairs
      Lenovo g50-80 charging led flashing but laptop not switching on
      by B2L_Repairs
      I got a lenovo g50-80 that shows charging led (orange LED flashing) and when I press the power button the white LED comes on but the laptop doesn't switch on. The fan spins for 2 seconds when I press the power button then it stops. This problem started when my charging dock broke the connecting wires and i soldered these wires back but I might have mixed them. I ended up buying a new charging dock but laptop never switched on it just shows flashing orange LED when charger is connected. Could the super io be bad? I don't know how to go about diagnosing and I can't check any board view since this...
      01-19-2025, 12:28 PM
