hp victus 15 with no power problem
  • Nabilos92
    • Dec 2019
    • 22
    • tunisia
    assalam alaikom every one
    i have hp victus 15 with no power problem i see that there is a hot temperature at rw=9d
    also there is a short with 3 capacitor behind him
    can any one help me please
  • mon2
    • Dec 2019
    • 14094
    Re: hp victus 15 with no power problem
    Hello. Remove all power. Meter in resistance mode.
    Check the resistance to ground of each capacitor in this area. If the resistance is too low, cap or some part on this rail is shorted. This can cause the ic to heat up.
    Do you also see the cap heating up?
    As a quick test, you can flux and remove the shorted cap. Keep note of the cap and it's location.
    The regulator is from Richtek.
    • Nabilos92
      • Dec 2019
      • 22
      • tunisia
      ok i will check what capacitor is shorted can you please tell me about that ic his rule
      • mon2
        • Dec 2019
        • 14094
        So far, unable to locate this regulator or more details with the 'RW=' markings by Richtek.
        Also cannot find this logic board in my database.
        Post more pics of this area of the logic board. Is this part on the main logic board? Any silk screened parts in this area?
        Often, the logic boards will be similar to others from the same vendor so that can be used to locate the component details.
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          RT6338BGQUF
          https://cdn.badcaps-static.com/pdfs/...3c980a4d7c.pdf
          Become a Badcaps supporter
          Thanks to all supporters.​
          • mon2
            • Dec 2019
            • 14094
            Nice! Could not find this in the Richtek database or google searches.
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Agree, cannot be found easily.
              Good luck solving the problem here.
              I don't have a good hunch about the outcome though.
              Shorted 3.3V = more problems (most of the times).
              You know what I mean.
              • piernov
                • Jan 2016
                • 4435
                • France
                Add YM after product code.
                • mon2
                  • Dec 2019
                  • 14094
                  Yes, that worked thanks.
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • Duranitron
                    Asus x512dk rev 2.1 power on problem
                    by Duranitron
                    When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                    Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                    11-26-2024, 10:22 PM
                  • EazyBone
                    LG OLED55C9PUA power problem
                    by EazyBone
                    Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                    Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                    I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                    The power supply to t con is different story.
                    This...
                    06-23-2023, 07:43 AM
                  • Dr.d
                    Help please..Lenovo ideapad 5 14itl05 power and charging problem
                    by Dr.d
                    I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                    Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                    04-05-2024, 11:48 AM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
