Lenovo 100-15idb NM-A681 no turning on
  • mon2
    • Dec 2019
    • 13834
    Re: Lenovo 100-15idb NM-A681 no turning on
    Yes. Agree that this component is likely defective.
    You can check the same resistance values on the component while it is on your work table.
    Check the resistance between:
    source & drain
    source & gate
    gate & drain
    There are 2 such mosfets inside this single package so check both.
    A low resistance on any of the above checks means the mosfet is defective.
    With the logic '1' = ~3v on the gate on a 2N7002, the mosfet should be ON.
    When the mosfet is ON, the lower resistor on the above portion of the schematic will build a voltage divider to lower the Vin voltage. When the gate voltage is at a lower potential, the P-channel mosfets (DCin) will enable and then pass the voltage onto the main logic board.
    As a quick test, now that this dual mosfet is removed, ground the gate pin of the DCin mosfets. This will force the DCin mosfets to enable.
    • xRaPiDxX
      • Feb 2021
      • 35
      • Poland
      Thanks for help, I replaced PQ307. Now laptop turns on but with no display, cpu is cold.
      I measured coils:
      PL9: 1.6985V
      PL701: 1.0474V
      PL304: 5.078V
      PL303: 3,371V
      PL501: 1,3557V
      Bios chip Has 3,370V.
      Power supply consumes 0.098a when turns on.
      If I shutdown through button it consumes 0.011a.
      I programmed bios and changed ram nothing changed.
      • mon2
        • Dec 2019
        • 13834
        That is 98 mA and is a very low current for a laptop.
        Check the voltage to ground on each power rail / coil. Someone is off.
        Confirm the main power rail voltage to ground after the DCin mosfets.
        • xRaPiDxX
          • Feb 2021
          • 35
          • Poland
          I measured coils, measurments in attachments and checked pq40 and pq39. Should I replace them because of low resistance?
          PQ40
          S:4,45 voltage to ground
          G:16,148 voltage to ground
          D:20,10 voltage to ground
          diode test: 0,53V
          Source - drain: 2mohm and goes down (no power)
          Source - Gate: 1ohm (no power)
          Gate - drain: 13mohm and goes down (no power)
          PQ39
          S:0 voltage to ground
          G:4,4528 voltage to ground
          D:4,32 voltage to ground
          diode test: 0,0767V
          Source - drain: 37,48ohm (no power)
          Source - Gate: 10mohm and goes down (no power)
          Gate - drain: 11mohm and goes down (no power)
          • mon2
            • Dec 2019
            • 13834
            Yes, they both look bad but remove each and check their resistance again when they are off the logic board and on your work table.
            If the resistance remains to be low, replace the mosfet.
            Post the measurements. On a good mosfet, the resistance should be high.
            Start with removing one mosfet to check if it impacts the resistance of the other.
            • xRaPiDxX
              • Feb 2021
              • 35
              • Poland
              #26
              PQ40 without PQ40:
              Source - drain: 1.8mohm and goes down (no power)
              Source - Gate: 2.3kohm and goes up (no power)
              Gate - drain: 0.75mohm and goes down (no power)
              PQ39(soldered) without PQ40:
              Source - drain: 36,47ohm (no power)
              Gate - drain: 6.4mohm and goes down (no power)
              PQ39 without PQ 39:
              Source - drain: 32,87ohm (no power)
              Gate - drain: 5.5mohm and goes down (no power
              PQ40(soldered) without PQ39:
              Source - drain: 0.63mohm and goes up (no power)
              Source - Gate: 0.2833mohm (no power)
              Gate - drain: 0.79mohm and goes down (no power)
              So source - drain on PQ39 is still low. Should I first try to replace both mosfets?
              • mon2
                • Dec 2019
                • 13834
                Appears that PQ39 is the defective one so yes, replace it.
                • xRaPiDxX
                  • Feb 2021
                  • 35
                  • Poland
                  #28
                  Okay so I replaced PQ39 still no display, CPU cold.
                  NOW:
                  PQ39
                  G:4,4519 voltage to ground
                  D: ~8,50 voltage to ground
                  Source - drain: 35,46 ohm (no power)
                  Source - Gate: 9,812 mohm (no power)
                  Gate - drain: 6,382 mohm (no power)
                  Power consumption is the same.
                  • Stevedb
                    Stevedb
                    • Feb 2018
                    • 622
                    • Belgium
                    #29
                    If you got the same reading without mosfet on pq39.
                    Then there is something else what partial shorted is .you mus find first what that is before you continue. Is there shematic available?
                    • xRaPiDxX
                      • Feb 2021
                      • 35
                      • Poland
                      #30
                      Yes schematic and boardview are available. I use them from this post: https://www.badcaps.net/forum/showth...37#post1044937
                      Yes, but I do not know where to start measuring now.
                      • xRaPiDxX
                        • Feb 2021
                        • 35
                        • Poland
                        #31
                        I have 32ohm on the second pin of PC97. Should I remove PU908 to check if resistance increase or is 32 ohm good for this line?
                        • Stevedb
                          Stevedb
                          • Feb 2018
                          • 622
                          • Belgium
                          #32
                          When one off the buck converter is defect you need to Replace the low side , high side and driver ic together. I will remove pq38 , pq39 and pu908 and see if you have still the low reading on D-S on pq39 .
                          • xRaPiDxX
                            • Feb 2021
                            • 35
                            • Poland
                            #33
                            I removed PQ39, PQ40 and PU908.
                            S-D on PQ39 now: 36,18ohm
                            • Stevedb
                              Stevedb
                              • Feb 2018
                              • 622
                              • Belgium
                              #34
                              You need to remove the partial short. How much resistance you have to ground there S -Ground.
                              • xRaPiDxX
                                • Feb 2021
                                • 35
                                • Poland
                                #35
                                PQ39 (no soldered) resistance to ground
                                S: GND
                                G: out of range
                                D: 37,68ohm
                                PQ40 (no soldered) resistance to ground:
                                S: 37,98 ohm
                                G: out of range
                                D: 0,36 mohm and increase
                                • Stevedb
                                  Stevedb
                                  • Feb 2018
                                  • 622
                                  • Belgium
                                  #36
                                  Do you have power supply inject 0.9v 1A and increase amps if needed but not the voltage and see what is getting hot.
                                  • xRaPiDxX
                                    • Feb 2021
                                    • 35
                                    • Poland
                                    #37
                                    With 0.9V it consumes only 0.030A. I can not feel any heat using my hands. I do not have thermal camera. Can I increase voltage?
                                    • mon2
                                      • Dec 2019
                                      • 13834
                                      See attached. Can you confirm that the measurements are from the correct mosfets?
                                      It is important to confirm as the ~37 ohms to ground may very well be the CPU rail resistance.
                                      Take the resistance to ground @ PL9 inductor - remove all power.
                                      What is the resistance @ PL9 ?
                                      • xRaPiDxX
                                        • Feb 2021
                                        • 35
                                        • Poland
                                        #39
                                        PL9 resistance to ground (NO PQ39, PQ40, PU908 soldered)
                                        PIN 1 - 35,86 ohm
                                        PIN 2 - 36,32 ohm
                                        so is this line correct?
                                        • mon2
                                          • Dec 2019
                                          • 13834
                                          This is the CPU vcore rail and by design, it will be a low voltage and respectively is a low resistance to ground rail.
                                          Unless this rail is extremely low in resistance, this resistance reading looks ok to me. If the CPU was shorted, then you may see extremely low resistance readings like 1 ohm or less.
                                          You can measure the resistance of the removed mosfets while they are off the logic board. If the mosfet readings are high then place them back.
                                          Each, the high side and the low side work together to lower the very high voltage used by the logic board to a safe value for the CPU core.
                                          After the above, confirm if the switching regulator for this rail is being enabled or not. This is pin # 1 of PU908.
                                          In either case, do not power up till both mosfets are onboard and confirmed to be soldered ok. Otherwise, if for example ONLY the high side mosfet is soldered but the low side is removed, then the regulator @ PU908 will assume both onboard and the CPU will be killed since there is no mosfet to lower the high voltage. Both mosfets must work together to lower the voltage to a safe value.
                                          • mferna14
                                            Lenovo Flex 5 15IIL05 not turning on
                                            by mferna14
                                            Dear precious friends., I am working on a Lenovo Flex 5 15IIL05 (Motherboard LC55-15C 19792-1 448.0K105.0011). The problem with it, does not turn on at all. I see the battery charging LED but no response from the power button. Output coils 3.3V & 5v are perfect. LDO 3V is also present, I measured this on the power button. The on/off button is working perfectly. I re-programmed with new bin files & the status is still the same. I do not see any abnormal voltage & any Shorts or any kind of liquid spill. The MB is clean. I am using this schematics Lenovo Flex 5-14IIL05 19792-1, seems...
                                            03-15-2025, 11:31 AM
                                            Lenovo 3000 Series Schematic
                                            Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                            3000 C100 laptop with Braille keyboard
                                            Lenovo 3000 C
                                            C100, C200 - 15-inch XGA screen
                                            Lenovo 3000 N
                                            N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                            N500 - 15.4 inch screen.
                                            Lenovo 3000 V
                                            V100, V200 - 12.1-inch WXGA models
                                            Lenovo 3000 G
                                            G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                            10-04-2024, 06:05 AM
                                            Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                            09-06-2024, 06:40 AM
                                            This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                            09-06-2024, 06:06 AM
                                          • derradji89
                                            Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                            by derradji89
                                            Hi everyone 🤗
                                            I have a Lenovo MIX 320-10lCR computer.**
                                            1. **Operating System**: Windows 10 ** Education** 64-bit.
                                            2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                            3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                            4. **BIOS Chip Reflashing**: Currently,...
                                            04-19-2025, 03:04 PM
