Lenovo 100-15idb NM-A681 no turning on
  • xRaPiDxX
    • Feb 2021
    • 35
    • Poland
    Hello, laptop is not turning on. Motherboard Mark: NM-A681 rev 1.0 UMA
    Here are the measurements I've taken:
    PR301:
    2.2mohm and goes down
    PQ301:
    S: 19.59V
    G: 19.575V
    D: 20.1V
    PQ302:
    S: 19,594V
    G: 19.576V
    D: 0,0022V
    Diode test: 0,5341V
    I don't have short circuit between S and G.
    What should I measure next? Please help
    Greetings 😁
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Lenovo 100-15idb NM-A681 no turning on
    Originally posted by lapfix
    lenovo ideapad 100 CG410/CG510 NM-A681 Schematic and BVD
    https://www.badcaps.net/forum/showth...37#post1044937
    Become a Badcaps supporter
    Thanks to all supporters.​
    • mon2
      • 13829
      Remove all power -> meter in resistance mode.
      Measure the resistance between the following pins on each of the above mosfets:
      source (1-2-3) & drain (5-6-7-8)
      source (1-2-3) & gate (4)
      gate (4) & drain (5-6-7-8)
      Post each measurement.
      • xRaPiDxX
        • Feb 2021
        • 35
        • Poland
        Thanks for reply. I checked signal ACOFF and there is 0v. I measured on 98 pin od kbc, so do I need to replace KBC? I still learn.
        • mon2
          • 13829
          Can you link or post the schematic? The above mosfets, are not enabled. If they are N-channel type, then gate voltage must be boosted to ~25v to enable. If P-channel, gate must be lower than the source / drain voltage.
          The charger IC will decide when to enable or not.
          Post the schematic link. Then post the resistance checks after removing all power. Checking if the mosfets are defective.
          • xRaPiDxX
            • Feb 2021
            • 35
            • Poland
            PQ301:
            Source - drain: 0.623mohm
            Source - Gate: 0.1955mohm
            Gate - drain: 0.44mohm
            PQ302:
            Source - drain: 0.27mohm and goes to 1mohm
            Source - Gate: 0.195mohm
            Gate - drain: 0.43mohm and increase to ~1mohm
            I use schematic and boardview from this post:
            • mon2
              • 13829
              Check the voltage to ground of PACIN.
              • xRaPiDxX
                • Feb 2021
                • 35
                • Poland
                Voltage to ground PACIN: 3.26V
                • mon2
                  • 13829
                  Locate PQ307B. Check the voltage to ground of pins 3, 4 and also 5. Post the readings.
                  • xRaPiDxX
                    • Feb 2021
                    • 35
                    • Poland
                    Pq307b:
                    3-0.0234v
                    4-gnd
                    5-0.0086v
                    • mon2
                      • 13829
                      Check the voltage to ground of pq998.
                      Next, remove all power. Meter in resistance mode. Check the resistance across pr309.
                      • xRaPiDxX
                        • Feb 2021
                        • 35
                        • Poland
                        Voltage to ground PQ998:
                        1-0.0086V
                        2-0.035V
                        3-GND
                        PR309- 31.82kohm
                        • mon2
                          • 13829
                          Check the voltage to ground of pr309. Check both sides.
                          • xRaPiDxX
                            • Feb 2021
                            • 35
                            • Poland
                            PR309
                            Pin 1 (PACIN) - 3.263V
                            Pin 2 (PACIN_G) - 0.0086V
                            • mon2
                              • 13829
                              Remove all power. Check the resistance to ground of pin #2 of pr309.
                              • xRaPiDxX
                                • Feb 2021
                                • 35
                                • Poland
                                Pin #2 of PR309: 128.30ohm
                                • mon2
                                  • 13829
                                  Flux and remove pq998. Then check the voltage again on each side of pr309.
                                  • xRaPiDxX
                                    • Feb 2021
                                    • 35
                                    • Poland
                                    After removing pq998:
                                    PR309:
                                    1-3.259V
                                    2-0.0086V
                                    • mon2
                                      • 13829
                                      Something is wrong in this region. Flux and remove pq307. Then check the voltage again on each side of pr309. The resistance to ground on the gate pin should not be so low.
                                      • xRaPiDxX
                                        • Feb 2021
                                        • 35
                                        • Poland
                                        After removing PQ307
                                        1-3.32 voltage to ground, 100.67kohm (no power)
                                        2-3.309 voltage to ground, 147.77kohm (no power)
                                        So do i need to find and replace PQ307?
