UX435E: Water Damage
  • j.bisous
    • Apr 2021
    • 23
    • France
    I'm trying to fix this Asus UX435E which has been water damaged.
    I cleaned everything, removed a bad capacitor and he powered on. I access the bios just fine but a chip becomes mad hot and the laptop shuts down.
    It seems that this controller chip is faulty: its reference seems to be "AWDPN" or "AWS0PN"
    I tried to find reference on the web but no luck on this (seems to be very close to SY8288RAC with "AWS5MA").
    Can you help me finding the good reference?
    Thank you
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: UX435E: Water Damage
    Hi it is the same the first 2 or 3 letter give the ic typethe other 3 are year and badge number.
    • j.bisous
      • Apr 2021
      • 23
      • France
      Wow okay perfect then!
      Thank you very much!
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        It's sticky thread right above your request:
        IC Marking Codes and Datasheets
        Silergy
        Become a Badcaps supporter
        Thanks to all supporters.​
        • edugimeno
          Stagg sms12p audio amp has water damage
          by edugimeno
          Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
          I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
          There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
          There is only one signal wire connecting the first boards...
          05-24-2025, 06:00 AM
        • Joel Ohana
          Lenovo IdeaPad 3 15IAU7 that suffered water damage
          by Joel Ohana
          I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
          Symptoms:
          • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
          • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
          What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
          03-06-2025, 11:25 AM
        • abajor
          A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
          by abajor
          Like title says A2141 came in with Water Damage, customer desperately wants the data.
          The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
          I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
          That said after cleaning up the...
          12-21-2024, 07:16 PM
        • rtstorm
          HP EliteBook 840 G8 water damage - identify component
          by rtstorm
          Hello, i got an HP EliteBook 840 G8 that has water damage, and i found this component has damage on it U60600. What is that component? I have schematics and boardview and the par no is:
          SINERGY_SYV128RAC_QFN_20P i cannot fount it anywhere. Is this component have some other name?
          Here is schematics + boardview...
          09-18-2024, 05:36 PM
        • Andreasbest
          Lenovo Legion 5 Pro 16ACH6H Water Damage
          by Andreasbest
          Hello!
          Today i received a Legion 5 pro with motherboard NM-D562 that suffered water damage, no power at all, no led, no fans, nothing.
          I measure 20v on PQ5401 at pins 5, 6, 7 and 8 but 0v at 1, 2, 3 and 4.
          Is this normal?
          Thanks in advance!
          Schematics and boardview-> https://www.badcaps.net/forum/troubl...95#post3254995...
          07-08-2025, 01:17 AM
