Macbook A1466 820-3437-A no green light and fan speed full
  • Paul20
    • Jul 2022
    • 40
    • Italia
    Hi guys
    The PC in question starts automatically when the power supply is connected both with magsafe power supply and with bench power supply it behaves the same.
    This happens both when the pc is whole, i.e. with all the periferals connected, and only with the card removed from the case bare and raw.
    There is no light on the magsafe connector, the fan spins fast and nothing appears on the screen.
    I understand that the main voltages are present on the board, if I have checked correctly.
    PP15V_TBT is not present.
    There is no obvious oxide damage or the like, or anything like that.
    It seems to me that I only noticed a sort of small hole on the Q5820, I am attaching the photos (apologies if they are not crystal clear) TBT Sensor.
    Could that be the cause? What can I check?
    I gladly accept advice.
  • mon2
    • Dec 2019
    • 14119
    Re: Macbook A1466 820-3437-A no green light and fan speed full
    No green / orange light means you do not have the PP3V42_G3H power rail which is used to power the single wire communication of the magsafe interface (head only for your case). This single wire communication is used to soft start a true Liteon (Apple original) power supply and is also used to index the green / orange LED inside the magsafe head.
    Select your meter to DC 20v or higher voltage scale.
    Measure the voltage to ground of each point (with your power adapter connected) of:
    D7005, pin # 1; Red probe on this pin; black to ground
    D7005, pin # 2
    D7005, pin # 3
    Then check the voltage to ground of PP3V42_G3H @ L7095.
    Post each measurement.
    • Paul20
      • Jul 2022
      • 40
      • Italia
      Here are the voltages:
      D7005 pin n. 1 - 8.12V
      D7005 pin n. 2 - 14.66V
      D7005 pin n. 3 - 14.39V
      L7095 PP3V42_G3H - 3.40V
      • mon2
        • Dec 2019
        • 14119
        What is the voltage to ground of ppbus_g3h?
        • Paul20
          • Jul 2022
          • 40
          • Italia
          ppbus_g3h - 8.11V
          • mon2
            • Dec 2019
            • 14119
            Review the first case here:
            https://repair.wiki/index.php?title=...e_view_desktop
            Linked to the SMC unable to communicate with the ISL to boost this ppbus_g3h voltage.
            Do check the voltage to ground of the smbus SDA and SCL lines on the isl part.
            High fan speed = faulty sensor readings = faulty smbus communication.
            • reformatt
              • Feb 2020
              • 1406
              Most common problem is SMC is stuck in reset (SMC_RESET_L is stuck low). Usually corrosion around U5110 or J6100. Also check for presence of PP3V3_S5_AVREF_SMC
              • Paul20
                • Jul 2022
                • 40
                • Italia
                Smbus SDA and SCL lines on the ISL part - 3.39V
                Other measurements:
                PPBUS_G3H - 8.12V
                It's low because from how I understand it it should be 8.55V
                (as from Louis Rossmann's video)
                L7095 on pin 1- 2.85V pin 2 - 3.41V
                Also from Louis' video, I saw that on pin 1 of L7095 I should have 3.42
                • Paul20
                  • Jul 2022
                  • 40
                  • Italia
                  Around U5110 and J6100 there are no signs of corrosion.
                  I noticed a sign of corrosion near U5000 and exactly on pin 1 of C5125 (PP3V3_S5_AVREF_SMC that you asked to check)
                  There is 3.28V at this same point
                  • mon2
                    • Dec 2019
                    • 14119
                    L7095 pp3v42_g3h - 3.40v
                    Your reading is very close but remove all power. Measure the resistance to ground of the same L7095 inductor.
                    • Paul20
                      • Jul 2022
                      • 40
                      • Italia
                      Red probe diode mode at ground if I understand correctly
                      0.330
                      • Paul20
                        • Jul 2022
                        • 40
                        • Italia
                        0.330
                        • mon2
                          • Dec 2019
                          • 14119
                          We are after the resistance check so meter in resistance mode.
                          One probe (any color) to L7095. Other probe to ground. Resistance will be in ohms.
                          If you see '1' or 'OL' then the meter scale is too low so switch to a higher scale.
                          • Paul20
                            • Jul 2022
                            • 40
                            • Italia
                            Ok sorry for the misunderstanding.
                            488 kohm
                            • mon2
                              • Dec 2019
                              • 14119
                              Resistance is ok, although is futile (Star Trek).
                              Voltage is ok.
                              Measure the voltage to ground of SMC_RESET_L signal.
                              • Paul20
                                • Jul 2022
                                • 40
                                • Italia
                                resistance is ok, although is futile (star trek).
                                Voltage is ok.
                                Measure the voltage to ground of smc_reset_l signal.
                                3.05v
                                • mon2
                                  • Dec 2019
                                  • 14119
                                  SMC is not stuck low.
                                  Measure the voltage to ground of PP3V3_S5_AVREF_SMC.
                                  • Paul20
                                    • Jul 2022
                                    • 40
                                    • Italia
                                    This I had already explained this in the post #9
                                    PP3V3_S5_AVREF_SMC - 3,28V
                                    • mon2
                                      • Dec 2019
                                      • 14119
                                      Can you post a pic of the area with corrosion ?
                                      U5000 (SMC) may need to be fluxed and reflowed.
                                      • Paul20
                                        • Jul 2022
                                        • 40
                                        • Italia
                                        So should I try a reflow on U5000?
                                        There is resin in the corners holding it in place.
