lenovo a451 no backlight or hdmi output
  • Thedan55
    forever learnin
    • Aug 2022
    • 37
    hey all
    ive worked on this model before and posted about that one here and found the solution. this is the same model but different machine.
    ive checked the fuses f6 f7 and they are fine, and im getting 3v on power on from lcd connector pin 33 or i think 34 35, one of them is backlight power, cant remember of the top of my head.
    so im leaning towards this being an actual lcd issue and not a board issue...
    just wanted to get some second opinions before ordering a display for this. is there a way to test the actual display? when shining a light i can see the lenovo logo so the backlight is definitely an issue.
    the thing that's confusing me is there's no display over hdmi either. in the past windows wouldn't boot because i needed to confirm something in the bios or something cant remember but once i repaired the fuse it all worked great.
    cheers!!
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: lenovo a451 no backlight or hdmi output
    JEDP1: Pin 33 & 34 - 3.3V, pin 37,38,39 & 40 - 20V, pin 19,20,21 & 22 - 3.3V
    Check these first. If all is OK, check the display pcb fuses.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Thedan55
      forever learnin
      • Aug 2022
      • 37
      will do, are these voltages in standby or while powering on? f6 and f7 are display fuses if im not mistaken and they're fine
      • Thedan55
        forever learnin
        • Aug 2022
        • 37
        right i know i checked 33 and 34 before and had 3v. backlight cntrl only has 1.2v but backlight on has 3v.
        does that mean a controller is damaged?
        edit: 20v on the 37 to 40. 3.3v on 19 to 22
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Check again the PANEL_BKLT_CTRL line voltage at test point TP57, if it's low again, check the resistance to ground at that line with and without connected display, inspect edp and JEDP1 connectors for corroded or bent pins, and finally check voltages at the CBT3257ABQ (U7).
          • Thedan55
            forever learnin
            • Aug 2022
            • 37
            resistance to g OL with and without display at tp57.
            u7
            pin11 0v. 9 and 10 1.2v
            pin16 5v
            pin 5 0v, 6 and 7 3.3v
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Inject 3V at test test point tp57, backlight must turn on, just to check if the machine (and the display) is working at all, or not.
              • Thedan55
                forever learnin
                • Aug 2022
                • 37
                Injected voltage not backlight
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Originally posted by Thedan55
                  ...are these voltages in standby or while powering on?
                  While powering on, after the power on button has been pressed of course.
                  If the cable is OK should work, In that case as I said check the fuses at the pcb board of the display, the cable itself, or test with any other screen.
                  • Thedan55
                    forever learnin
                    • Aug 2022
                    • 37
                    Fuses are good, cable and connectors look good. I have image but no backlight even after injecting. Unfortunately i don't have another display. Seems like the display is bad?
                    • Thedan55
                      forever learnin
                      • Aug 2022
                      • 37
                      It's sorted ��������
                      Previous tech that replaced screen didn't secure it correctly and the flex on the LCD had come loose ��������������
                      After all that!
                      Thank you for your help! Genuinely appreciated mate @vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        You're welcome. Well done!
                        Cheers
                        • coasterghost
                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                          by coasterghost
                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                          System Hardware:
                          Processor: AMD Ryzen 7 PRO 5850U
                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                          09-08-2025, 10:46 PM
                        • budwich
                          ESD Diode on HDMI output of Yamaha a1050 RCVR
                          by budwich
                          I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
                          I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
                          09-11-2023, 12:21 PM
                        • amigo744
                          ps5 cfi-1016a hdmi output graphics glitches ???
                          by amigo744
                          i have a ps5 here, which only produces graphic artefacts on the screen when the console shuts down.
                          no graphic artefacts visible in ps4 and ps5 games.
                          when the console is started, no artefacts can be seen in the main menu!
                          It's all very strange and I don't know what to do next
                          I swapped the hdmi port, no change.
                          could it be the hdmi encoder or the components near the hdmi ports?
                          how are the hdmi filters checked for functionality?
                          https://youtu.be/cOCapeDOMZk
                          Have anybody here same problem with hdmi...
                          08-11-2023, 05:42 AM
                        • Prosatanosz
                          Asus B85M-GAMER no hdmi output and random restarts
                          by Prosatanosz
                          Hi!
                          Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
                          10-19-2024, 05:27 AM
                        • Jayanta
                          Acer Nitro 5 AN515-55 no HDMI output.
                          by Jayanta
                          Hello, forum people.
                          I have an Acer Nitro 5
                          Model Number: AN515-55 Part Number: NH.Q7NSI.001
                          Motherboard: Compal GH51M LA-K861P Rev 1A with 1650 Ti graphics.
                          My laptop was working fine until I made a grave mistake of changing the thermal pad and paste because my laptop was getting old and pretty hot. After changing and successfully testing temperatures, I was shocked when I tried to connect my external display, a 1440p 75Hz monitor, to it. My display never showed up; it always said 'no signal.' I tried swapping the HDMI cable, using both source 1 and 2 on...
                          06-17-2024, 02:49 AM
