820-3330-B A1286 Image, No Backlight
  • diesel1024
    • Apr 2023
    • 6
    Hey guys,
    Looking for a bit of advice here, I'm very new board repair specifically. Randomly the backlight stopped working on my Mid 2012 15" MBP 2.3 Unibody. Had left it for a few hours and came back to the backlight no longer working. To note, I keep the bottom panel unscrewed due to the ram slot issues, so it is a very small possibility something could've gotten nicked. I measured some voltages, so here's what I got:
    10.71V on both sides of F9700 (PPBUS_G3H) & (PPBUS_S0_LCDBKLT_FUSED)
    Continuity to R9788 & C9782
    Q9707 only thing that looked even a bit damaged (https://imgur.com/a/lLBdXvs)
    Pin 2 - 3.28 (LCD_BKLT_EN)
    Pin 5 - 3.26 (BKLT_PLT_RST_L)
    0V on 38-40 of J9000 (PPVOUT_S0_LCDBKLT)
    Hoping this can get me somewhere to look next, already tried multiple SMC and PRAM resets
    I have at least one spare parts board too, so I theoretically could swap things to an extent.
  • mon2
    • Dec 2019
    • 14662
    Re: 820-3330-B A1286 Image, No Backlight
    Not at my desk but is the nicked part linked to the lcd backlight? Was this part nicked before or after losing the backlight
    • diesel1024
      • Apr 2023
      • 6
      I unfortunately do not know if it was nicked before or after, all I know is it is currently nicked. It looks to be linked to the lcd backlight in some ways. From what I can tell it looks like it controls the enabling and disabling of the backlight based on the trace/pin names.
      • mon2
        • Dec 2019
        • 14662
        See attached. The nicked mosfet is a voltage divider enabler mosfet.
        When ON, the ground connection mates onto R9789 to allow for the common junction between R9789 & R9788 to build a voltage divider.
        If the nicked mosfet is ON (for both sections as there are 2 in a single package), then the GATE voltage of Q9706 will be LOWER than the voltage being passed between the source / drain pins of Q9706.
        Mosfets are like solid state switches / relays. The mosfet @ Q9706 is a P-channel mosfet. So this mosfet will enable only if the gate voltage is LOWER than the source / drain pins.
        Carefully measure the voltage to ground readings of the Q9706 mosfet.
        Interested in the SOURCE, DRAIN and GATE pin voltages.
        If the GATE voltage is the same as the voltage seen on pin # 4 of Q9706, then this mosfet is OFF since the voltage divider is not active.
        Confirm and post the measurements.
        • diesel1024
          • Apr 2023
          • 6
          I haven't had a chance to get those measurements, but I looked back at the board today, and comparing it to a 2011 2.4 i7 board (820-2915) I noticed a component next to Q9707 was actually completely missing, and according to this diagram, it looks like that is a point which LCDBKLT_EN_DIV goes through to LCDBKLT_EN_L. I'm going to try to replace the cap/resistor, whatever it may be and see if that fixes it. My donor 820-2530 has two of these:
          147K
          1%
          1/16W MF-LF
          402
          Will update.
          • diesel1024
            • Apr 2023
            • 6
            Update, added some solder to the pads where the missing component was, took R7408 from 820-2530, soldered it to the pads on my 820-3330-B, it isn't pretty, but to my amazement, I now have backlight, so from what I can tell Q9707 is fine besides having that cosmetic damage. Now only time will tell if it'll last.
            Thank you for your help mon2!
            • diesel1024
              • Apr 2023
              • 6
              photos
              • mon2
                • Dec 2019
                • 14662
                Well done and thanks for the updates.
                • Salem Aboshala
                  820-00138-A got image but no backlight
                  by Salem Aboshala
                  Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                  I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                  History: my laptop backlight stopped working without any reason.
                  Symptoms:
                  I have image on screen using my flashlight.
                  I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                  Keyboard backlight still working and can be adjusted normally.
                  Since two days I tried to follow all similar...
                  06-11-2024, 03:02 PM
                • zaurus81
                  Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                  by zaurus81
                  This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                  The board is equipped...
                  01-16-2025, 03:54 AM
                • Constantinos
                  Macbook Pro A2442 820-02098 No image but has backlight
                  by Constantinos
                  Hi all
                  I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                  He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                  Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                  Obviously, he decided against this and gave it to me so that I could have a crack at it.
                  From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                  08-24-2024, 09:48 AM
                • ajgae
                  HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                  by ajgae
                  Hi everyone!
                  First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                  03-06-2025, 09:53 AM
                • learnmore
                  Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                  by learnmore
                  Hello Community!
                  CASE DETAILS
                  Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                  13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                  Tried inserting firmware on USB and left it in for a few hours, but no change
                  03-03-2024, 09:49 AM
