MSI Power On Problem
  • motanya
    • Nov 2021
    • 162
    • Kenya
    What might be the problem with this MSI laptop, if switched off at night it does not power on in the morning unless the reset button at the back is pressed. This means if it stays off for a while it will not power on using the power button unless you reset but if it is a short power off it will power on.
    • 21936
    Re: MSI Power On Problem
    Does this MSI laptop have a model number, is there a schematic available that you can link to or post.
    • motanya
      • Nov 2021
      • 162
      • Kenya
      model number MS-16Q2
      Can't find the schematic
      • motanya
        • Nov 2021
        • 162
        • Kenya
        Anyone with a solution kindly help
        • mon2
          • Dec 2019
          • 14677
          Remove the battery and test with only the adapter. Any change in the issue?
          Then remove adapter and use battery only. Any change?
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Duranitron
            Asus x512dk rev 2.1 power on problem
            by Duranitron
            When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
            Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
            11-26-2024, 10:22 PM
          • EazyBone
            LG OLED55C9PUA power problem
            by EazyBone
            Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
            Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
            I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
            The power supply to t con is different story.
            This...
            06-23-2023, 07:43 AM
          • Dr.d
            Help please..Lenovo ideapad 5 14itl05 power and charging problem
            by Dr.d
            I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
            Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
            04-05-2024, 11:48 AM
            by sam_sam_sam
            03-31-2024, 02:12 PM
