Macbook A1466 820-3437
  • Instafixx
    • Jul 2022
    • 374
    • India
    I have a Macbook A1466 820-3437 which came to me in dead condition. The charger has a proper Green/Orange light PP3v42 is ok.
    Getting 8.58V on PPBUS_G3H.
    I know that this Macbook exhibits the Fan on/off/on/off/on symptom before a bare boot.
    But in my case first the fan spins normally for about 15 seconds , the it stops. Then it starts spinning again and after 15 seconds it goes on a high spin.
    While checking the board i noticed that whenever i probe SMC_RESET_L anywhere on the board - the fan stops to spin.
    Has anyone experienced something similar or has anyone make out what am i doing wrong ?
  • mon2
    • 14334
    Re: Macbook A1466 820-3437
    Measure the voltage to ground of CPU_VCCST_PWRGD.
    • Instafixx
      • Jul 2022
      • 374
      • India
      Its 1.05V checked at Pin#2 of R1931
      • dellxps15
        • Feb 2014
        • 1591
        • italy
        all_sys_pwrgd voltage on u1950 ?
        post u1950 volts when fan spinning.
        • mon2
          • 14334
          Voltage to ground of ALL_SYS_PWRGD?
          • Instafixx
            • Jul 2022
            • 374
            • India
            Getting a stable 3.3V at U1950.
            • mon2
              • 14334
              Disconnect the trackpad/keyboard cable. Connect the power adapter.
              • dellxps15
                • Feb 2014
                • 1591
                • italy
                usb activity ? tried with external display ?
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  Booting the Bare Board. No peripherals connected.
                  • mon2
                    • 14334
                    Confirm the presence of the pull-up resistor on SMC_RESET_L.
                    • Instafixx
                      • Jul 2022
                      • 374
                      • India
                      No Booting Chime etc. Do you think external display will work?
                      • Instafixx
                        • Jul 2022
                        • 374
                        • India
                        Both R5100 and R7100 are present . No short on ground.
                        • mon2
                          • 14334
                          What is the voltage to ground of SMC_RESET_L ?
                          If your meter probes cause this line to be flaky, something is wrong with this signal line.
                          • Instafixx
                            • Jul 2022
                            • 374
                            • India
                            Getting 3.12V
                            • mon2
                              • 14334
                              The pull-up resistor @ R5100 is to 3v42. Confirm the voltage to ground of the 3v42 rail.
                              Remove all power -> measure the resistance across R5100.
                              Update:
                              Also confirm the voltage to ground of L5001 (both sides)
                              • Instafixx
                                • Jul 2022
                                • 374
                                • India
                                R5100
                                Voltages
                                Pin 1 is 3.46V
                                Pin 2 is 3.17V
                                Resistances (Meter in 2K Mode. Red to Ground)
                                Pin 1 has .261
                                Pin 2 has .464
                                • mon2
                                  • 14334
                                  The resistor @ R5100 should be ~100k ohms.
                                  Confirm that your meter scale is 100k or higher. Meter probes across R5100 resistor. No power to the board in checking the resistance.
                                  • Instafixx
                                    • Jul 2022
                                    • 374
                                    • India
                                    Checked with Meter Set to 200K Scale.
                                    Pin 1 is 168
                                    Pin 2 is 67
                                    Red to Ground.
                                    • mon2
                                      • 14334
                                      Review and read the posts carefully.
                                      We are not checking the resistance to ground.
                                      Checking the resistance of the component.
                                      Again, meter across the component.
                                      • Instafixx
                                        • Jul 2022
                                        • 374
                                        • India
                                        My Apologies. Meter set to 200k
                                        Red on Pin 1
                                        Black on Pin 2
                                        Meter reading is 91.6
