Dell precision m4800 not detecting battery
  • maren1
    • Feb 2022
    • 20
    • nigeria
    I need help with dell precision m4800 that dont detect battery. i try all the trobleshooting change battery,do hard reset , everything i know not work.it only power with the adapter and the charging led will be blinking orange light fast please some one here should help on how to fix this problem.
  • mon2
    • Dec 2019
    • 13994
    Re: Dell precision m4800 not detecting battery
    Measure the voltage to ground of each pin of the battery connector. Post the measurements.
    • maren1
      • Feb 2022
      • 20
      • nigeria
      here is the reading-----
      • mon2
        • Dec 2019
        • 13994
        These measurements look ok. We are checking if the smbus lines are stuck or not. You have ~3v on the lines so they are not stuck.
        Next, you will need to attach the battery and measure the voltage to ground of these pins again.
        Are you able to take the logic board out of the enclosure for more measurements?
        We need to check some readings of the charger IC.
        Does this laptop function ok with only the power adapter? Does the bios report the correct power rating of the power adapter?
        If you boot into windows, does the laptop show the battery graphics?
        • maren1
          • Feb 2022
          • 20
          • nigeria
          the laptop function very well with the adapter.
          i dont really know the bios rating power of the adapter.
          yes the laptop show the battery graphic with X mark on it.
          • mon2
            • Dec 2019
            • 13994
            Does the laptop ever complain about 'unknown power adapter ' ?
            Are you able to take voltage measurements of the battery connector with the battery connected? Then we can check the battery present pin voltage.
            Has this laptop ever been exposed to liquid damage? Just stopped working with the battery one day?
            Is the battery with enough of a charge at this time to be able to power the logic board?
            • maren1
              • Feb 2022
              • 20
              • nigeria
              measurement with the battery attached no
              liquid damage not at all
              i have used different new battery with enough current not work not even power the laptop.
              • mon2
                • Dec 2019
                • 13994
                Not at my computer but need to review the charger IC. This charger IC will have local mosfets that act like switches to enable or disable the use of the battery if the adapter is missing.
                The charger IC monitors the battery status and also will charge the battery if the adapter is suitable with enough power. The batteries must be known good batteries.
                Do check the battery contacts.
                Which charger IC is onboard? Is it the usual BQ series? Share the topside markings of this charger IC. Will check the same once at my desk.
                • maren1
                  • Feb 2022
                  • 20
                  • nigeria
                  ok sir
                  i will detach the now show you all about it.
                  • maren1
                    • Feb 2022
                    • 20
                    • nigeria
                    here is some pictures of the charging area of the board---
                    • mon2
                      • Dec 2019
                      • 13994
                      1) The schematic for this logic board is posted here:
                      https://www.badcaps.net/forum/showth...ighlight=M4800
                      2) See attached. Remove the battery and power up with only the power adapter.
                      Measure the voltage to ground of pin # 5 = PBAT_PRES# pin.
                      This pin has a local pull-up resistor @ PR2. Without the battery, this voltage to ground should be ~3 volts.
                      With battery connected, PBAT_PRES# = 0 volts.
                      Without battery connected, PBAT_PRES# = ~3 volts.
                      Confirm it.
                      3) Charger IC is @ PU700 = BQ24737RGRR
                      • maren1
                        • Feb 2022
                        • 20
                        • nigeria
                        Confirm it.
                        yes comfirmed pin # 5 without battery =3 volts and 0 volt with battery
                        PR2 resistor also 3 volts without battery.
                        • mon2
                          • Dec 2019
                          • 13994
                          These are good readings. Is the battery the original? Can you test with another known good battery?
                          What is the history of this laptop?
                          • maren1
                            • Feb 2022
                            • 20
                            • nigeria
                            the battery is original that come with the laptop and i also get a new different battery from different store still not working.
                            the problem is battery not detected with X mark shown on the battery graphic.
                            • mon2
                              • Dec 2019
                              • 13994
                              Remove all power. Meter in resistance mode.
                              Check the resistance of the resistor network at PR3.
                              One meter probe on pin #3 of the battery connector. Other meter probe to pbat_smbclk. Reading should be ~100 ohms.
                              Repeat for pbat_smbdat line.
                              Post your measurements.
                              • maren1
                                • Feb 2022
                                • 20
                                • nigeria
                                here is the reading
                                • maren1
                                  • Feb 2022
                                  • 20
                                  • nigeria
                                  but dont understand how to read this line----
                                  • mon2
                                    • Dec 2019
                                    • 13994
                                    See attached.
                                    Use the meter probes across the resistor network with the RED arrows.
                                    Then repeat the same test with the probes at the YELLOW arrows.
                                    Each should return a value of ~100 ohms. We are only checking to be sure that PR3 resistor network is ok.
                                    • maren1
                                      • Feb 2022
                                      • 20
                                      • nigeria
                                      See attached.
                                      here is what i have---
                                      • mon2
                                        • Dec 2019
                                        • 13994
                                        These are very high readings.
                                        The resistance should be ~100 ohms for each check, not in the Kohms.
                                        Can you short your meter probes and post the measurement?
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • tomodachi
                                          Dell Precision 5510 " Not a Dell Battery"
                                          by tomodachi
                                          Hi
                                          Dell Precision 5510
                                          Mobo code : LA-C361P
                                          This one came in for battery replacement but without original battery, so original battery and charging history is unknown.
                                          The customer said he bought the computer several years ago second-hand and was told that there was no battery inside but that he could purchase one if he wanted.
                                          So we ordered a geniune battery for customer, plugged it in
                                          RTC battery was also dead and it was also replaced. First boot up brought up warning message;
                                          Funny thing is Service Tag is already set.
                                          And...
                                          11-07-2024, 06:08 AM
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                          DELL Precision T3620 Precision E3-1240V5 Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3620 boardview and Precision T3620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-12-2024, 03:44 PM
                                          DELL Precision 3630 Precision i7-9700 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3630 boardview and Precision 3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
