Newbie schematic reader - please help
  • survivalbloke
    • Aug 2021
    • 262
    I've attached a schematic of the board I'm looking at. The LCD backlight is not working and I'm trying to determine how that circuit is protected. What is the easiest means of finding this circuit on any given schematic?
    Thanks!
  • mon2
    • Dec 2019
    • 13829
    Re: Newbie schematic reader - please help
    Search for the keywords like 'lcd' or 'backlight'. Important to try all permutations to find the portion of the schematic that is relevant to the work. For example there will be a backlight for the keyboard, etc. Lcd is a good one.
    • Sephir0th
      • Oct 2020
      • 1249
      Page 55. Main reason for missing backlight are issues with DCBATOUT_LCD, BLON_OUT_C and LCD_BRIGHTNESS. Check these lines for proper voltages with internal display attached.
      FairRepair on YouTube
      • survivalbloke
        • Aug 2021
        • 262
        Thank you!
        • survivalbloke
          • Aug 2021
          • 262
          Got it, and thank you. Guess I'm going to need a boardview for this. I'll see if I can scare up one of those and continue my checking.
          • Sephir0th
            • Oct 2020
            • 1249
            We might be able to lead you if you share clear pictures of your board
            • survivalbloke
              • Aug 2021
              • 262
              I'll take you up on that. Thanks!
              • Sephir0th
                • Oct 2020
                • 1249
                LCD1, Pin 1 is most right in this picture. You can measure DCBATOUT_LCD without display connected, but for the other signals you might want to find a better test point with multimeter, while the display is connected.
                • tranquility
                  newbie needs capacitor sizes. HP Spectre X360. schematic maybe available
                  by tranquility
                  hello, i am very new to laptop repair and generell electronics
                  i have a HP Spectre X360 Convertible 13 - ap0016ng
                  motherboard number DA0X36MBAE0 REV E
                  massive burned and shortet mosfets. after removing them still shortet in the i think "main power rail"
                  found a shorted capacitor. removed it and the short is gone.
                  i want to try a crazy repair which is hard because the mosfets are like welded on one side to the track. is there a method to get this loose ?
                  in this area another capacitor was shortet.
                  12-06-2024, 04:12 AM
                • Astonished
                  Fixing the Charge Circuit of the Batteries of the DC Motor
                  by Astonished
                  Hi friends of electronics
                  What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                  The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                  Please help me fix this circuit.
                  (the datasheet of the IC: https://pdf.datasheet.live/28...
                  01-28-2025, 06:24 AM
                • TinkerTron
                  Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                  by TinkerTron
                  Hey everyone,
                  I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                  Instead, here's what's been bugging me so far:
                  The schematic...
                  03-06-2025, 02:03 PM
                • atunguyd
                  Acer x163w Monitor PSU schematic
                  by atunguyd
                  Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                  The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                  03-05-2025, 02:08 PM
                • Tarot Superstars
                  Short Circuit tester
                  by Tarot Superstars
                  Hello.
                  I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                  The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                  Link
                  The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                  https://www.youtube.com/watch?v=0eixDdCpiO4
                  My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                  09-25-2023, 09:11 AM
