Macbook Pro 2012 820-3115 Missing PP5V_SUS
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    hi guys gooday i have a macbook pro 820-3115 that i wanted to get up and running for personal use. it's stuck on 20 milliamps . It has green light.I measured some voltage rails and am stuck on PP5V_SUS missing. Hoping you guys can guide me further on other things to check thx.
    PPBUS_G3H= 12.56v
    PPBUS_S5_HS_COMPUTING_ISNS= 12.56v
    PP3V42_G3H= 3.4v
    PPVRTC_G3H= 3.3v
    PP5V_S5= 5v
    PP5V_SUS= 0v
    PP5V_S3= 0v
    PM_SLP_S4_L = 0v
    PM_SLP_S5_L = 0v
  • mon2
    • Dec 2019
    • 14263
    Re: Macbook Pro 2012 820-3115 Missing PP5V_SUS
    What are the voltage to ground readings for the following?
    PP5V_S5_P5VSUSFET
    P5V_3V3_SUS_EN
    • platinumsteel
      • May 2019
      • 234
      • Trinidad&Tobago
      PP5V_S5_P5VSUSFET
      P5V_3V3_SUS_EN
      PP5V_S5_P5VSUSFET = 5v
      P5V_3V3_SUS_EN = 0v
      Not sure am doing anything right.But trying to anticipate where you might ask me to check next.
      U7940 outputs P5V_3V3_SUS_EN ?
      PM_SLP_SUS_L 3.3v
      SMC_BATLOW_L = 0V
      • mon2
        • Dec 2019
        • 14263
        What is the voltage to ground of
        SMC_RESET_L ?
        ALL_SYS_PWRGD ?
        • platinumsteel
          • May 2019
          • 234
          • Trinidad&Tobago
          What is the voltage to ground of SMC_RESET_L ?
          SMC_RESET_L = 3.4v
          • mon2
            • Dec 2019
            • 14263
            Check ALL_SYS_PWRGD as well.
            • platinumsteel
              • May 2019
              • 234
              • Trinidad&Tobago
              ALL_SYS_PWRGD = 0v
              • mon2
                • Dec 2019
                • 14263
                So at least one of the power rails is not working.
                It is bringing this logic status to LOW. Every power good needs to be HIGH to indicate the power rails are working.
                The attached is the logic 'AND' gate built up from the power good signals.
                If each input is HIGH, this signal line is HIGH = good to go.
                If even one of the power good signals is low, then this signal will be LOW. A low on power good means the power rail is not working.
                To debug this, you can flux and remove the series resistors on this tree. One by one, confirm the power good signal is OK and is NOT low.
                • platinumsteel
                  • May 2019
                  • 234
                  • Trinidad&Tobago
                  Not to sure i understand what you mean. Do you mean remove the series resistors on left of U7960 according to the schematic one by one.And like each time i remove one resistor check to see if ALL_SYS_PWRGD returns ?
                  • mon2
                    • Dec 2019
                    • 14263
                    No. See above the purple highlighted signal that was posted.
                    That is the output 'AND' tree from each power good rail.
                    Remove each resistor with flux. Keep track of which parts you are removing. Then apply only one at a time back onto the board.
                    If even one signal is low, this output will be low. We need to know which one is low.
                    • platinumsteel
                      • May 2019
                      • 234
                      • Trinidad&Tobago
                      Okay just finished testing.I removed all resistors first checked for all_sys and nothing.So each one i put back in.I tested right after for all_sys and 0v for each time i put it in.All resistors are back in now.
                      • reformatt
                        • Feb 2020
                        • 1416
                        Originally posted by platinumsteel
                        SMC_BATLOW_L = 0V
                        Wasting your time until your sort this out. This level only goes high from the SMC when you have a 85W Magsafe 1 charger. It determines that via the one wire circuit.
                        I have a 60W genuine Magsafe 1 charger for the older Mac's and this line stays low on those. Only goes high with 85W chargers.
                        • platinumsteel
                          • May 2019
                          • 234
                          • Trinidad&Tobago
                          Well yeh i guess.Cause i only have a original 85w charger. And on my bench PSU am using a 85watt L- Tip cable. and i checked SMC_BATLOW on my other identical working board and yes it's 3.2v on that line.
                          Think i will try to get my hands on an SMC from a donor and replace it and see how it goes or if anything changes.
                          • reformatt
                            • Feb 2020
                            • 1416
                            There is a hack to bypass it if your SMC is bad. Fit a 0 ohm resistor to R7917, remove Q5040 and short pads 1 and 2 of that transistor.
                            • mon2
                              • Dec 2019
                              • 14263
                              Re:post #11
                              If you removed all power good resistors and still had a low, this means your pull-up voltage at very top of the tree is missing.
                              Check the pull up resistor and the voltage on the high side. Is it present?
                              • platinumsteel
                                • May 2019
                                • 234
                                • Trinidad&Tobago
                                Okay pal thanks a lot for the hack.It definitely works but well The board boots up I get CPU_VCORE . The boards stays on for like 8 seconds then goes off then back on and stays on for 8 seconds then goes off and stays stuck at 20 milliamps. One weird thing is i don't get fan spin. swapped fans but same. Possible there is something wrong elsewhere as well? Thinking i should not go further till i get a good SMC. lol
                                @mon2 Not to sure which pull up resistor to check.And the voltage on the high side.
                                • carlosfandango26
                                  macbook pro 2012 820-3115-b identifying missing components
                                  by carlosfandango26
                                  hi guys hope im in the right place for this topic... recently bought a used macbook pro 2012 and after doing a thermal repaste the power button will not work. however if i disconnect the battery it will power up from the charger and appears to work fine... ive searched on the board and i have found what appears to be 2 missing components R5710 and c5710
                                  must have snagged them when i was struggling with the keyboard ribbon.
                                  can anyone tell me what these are ie: capacitors, resistors and where i can get them from and how the hell to solder these flea size components back.. lol...
                                  06-20-2022, 11:23 AM
                                • Rezendes
                                  Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                                  by Rezendes
                                  Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                                  I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                                  The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                                  05-10-2024, 02:18 PM
                                • Adogabriel100
                                  Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                                  by Adogabriel100
                                  Hey! This is a A1278 macbook 2011.
                                  Problem: Not turning on / No green light
                                  Im using by3200s charger.
                                  Voltajes:
                                  PPBUS_G3H = 12.26v
                                  SMC_RESET_L = 3.3v
                                  PP3V42_G3H = 3.42v
                                  U7000 =
                                  Pin 1 CHGR_AGATE = 0v
                                  Pin 2 CHRG_DCIN = 19v
                                  Pin 3 CHRG_ACIN = 4.6v
                                  Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                                  Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                                  Pin 12 PP3V42_G3H = 3.42v
                                  Pin 13 CHRG_RST_L = 3.3V
                                  Pin 14 SMC_BC_ACOK = 0.8V
                                  Pin 19 PP5V1_CHRG_VDD = 5.05V
                                  Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                                  04-01-2024, 01:02 PM
                                • korben_dallas
                                  Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                  by korben_dallas
                                  Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                  I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                  I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                  MY QUESTION:
                                  I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                  02-14-2024, 12:23 AM
                                • bastien
                                  OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
                                  by bastien
                                  It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
                                  This is the new database for FlexBV
                                  it's optimized to work with it
                                  by using board ID has Default name, give us the opportunity,
                                  to use other diode board data with sibling board or family board
                                  I Merged the whole data (optimal)
                                  A2991 A2992 M3 -> -> 2 Entries diode data M1
                                  A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
                                  A2442 A2485 A2779...
                                  03-18-2025, 08:03 AM
