Dell E7440 turns on for 10-15 seconds then turns off
  • Zilicon
    • Nov 2020
    • 142
    • Nigeria
    Originally posted by PinGuy
    Re: Dell E7440 turns on for 10-15 seconds then turns off
    It was the original issue and it would not start even after changing the CMOS battery. Like as if the BIOS "forgot" its stuff when the CMOS battery died. I reflashed the BIOS and then it started to boot properly.
    But then it died again after not using it for a while, and the CMOS battery is fine at 3V this time. I believe it should start even without the CMOS battery, just taking longer to boot, but this one doesn't and the LED pattern is always the same, with or without the CMOS battery.
    The charger is tested fine, and there are no shorts on the mobo. Looks like some some "Management Engine" related shite that fails on powerup.
    Does the BIOS at U7 control the boot process? I haven't flashed that one.
    PinGuy what's the update?
    • Zilicon
      • Nov 2020
      • 142
      • Nigeria
      Originally posted by Magnusa2
      DELL E7440 NO POWER VOLTAGE IS OK. WHEN I PRESS POWER BUTTON JUST LIGHT ON POWER BUTTON LED FOR 15 SECONDS
      I HAVE SAME ISSUE MORE THAN 10 PIECES
      Magnusa2 it will be good to start another thread stating the problem. Avoid using upper case
      • Magnusa2
        • Jul 2017
        • 66
        • India
        ok
        • Zilicon
          • Nov 2020
          • 142
          • Nigeria
          ok
          With that being said. I think the problem is from the BIOS.
          Fetch a confirmed working BIOS and write it on the chip. remember to make a backup,
          • Magnusa2
            • Jul 2017
            • 66
            • India
            allready did
            • mon2
              • Dec 2019
              • 14351
              Continue to measure the voltage to ground on the mosfet @ PQ700 (source / gate / drain pins to ground). Post each measurement.
              Also interested in the voltages on PU700 for:
              VCC (pin #20)
              ACDET (pin #6)
              BQ24715_REGN (pin #16)
              ACOK (pin #5)
              Click image for larger version  Name:	charger_check.png Views:	0 Size:	883.4 KB ID:	3182057
              • Magnusa2
                • Jul 2017
                • 66
                • India
                #27
                VCC (pin #20)
                ACDET (pin #6)
                ACOK (pin #5)
                PQ700 S = 19.4v D = 1904v G = 0
                PU700,, pin20 = 19.3v ,, pin 6 = 3.1v ,, pin 16 = 6v ,, pin 5 = 3.2v
                • mon2
                  • Dec 2019
                  • 14351
                  These are good measurements. The referenced p-channel mosfet is being enabled to power the logic board. Are these measurements after 15 seconds?
                  Do test after the power led goes off after 15 seconds. Also check the voltage to ground of each onboard inductor. Report any low or odd voltage measurement. This can mean a short on that power rail. Be careful since power is on.
                  • Magnusa2
                    • Jul 2017
                    • 66
                    • India
                    #29
                    sorry sir idid't get time today .i will inform you latter
                      DELL Latitude E7440 Ultrabook 7000 Specification for Upgrade or Repair
                      This specification for the DELL Latitude E7440 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7440 boardview and E7440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                      09-06-2024, 04:40 PM
                      09-06-2024, 04:10 PM
                    • Kambi13
                      Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
                      by Kambi13
                      Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
                      Not heat related, everything is ok regarding to that.
                      All voltages are present.
                      Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
                      Motherboard is Cedar 13269-1 F3XMC Rev A00...
                      07-12-2024, 06:10 AM
                    • zklgfs
                      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                      by zklgfs
                      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                      08-11-2025, 02:14 PM
