A1286 820-2915-B CPU throttling
    Re: A1286 820-2915-B CPU throttling
    Originally posted by mon2 View Post
    Excellent! Thanks for the update. Did you apply any special board straps after the GPU was removed?
    sorry i dont get what you mean. i didnt put anything but just thermal pad for electrical insulation for the gpu heatsink, if thats what you meant.
      Originally posted by gurangax View Post
      Just have this problem today. throtled cpu. did you fix yours?
      Nah, haven't got around to it again. My hope sits with nongen battery but that is a long shot
      Do you have a genuine battery?
      Is you GPU working fine? Mine is and I don't want to remove it just to prove the theory.
      I can imagine it could pull SDA/CLK lines if it were shorted, that could cause throttling since no temp reading could be made
        Yup I have genuine original battery which comes with laptop. I bought this laptop for cheap from a guy who stored it after the screen went black. Turns out that it has been repaired before and I guess he doesnt want to repair it anymore probably because of high repair cost. The GPU was shorted before, it got too hot. So I removed the power coils for GPU core. that solve the problem which prevented the laptop to turn on. Soon (maybe a week later) it starts to throtle after using the cpu for high demanding app for long periods.
          so i spent a few hours on this again today - down to looking at SMBUS communications between SMC and U55* chips with logic analyzer.
          All looked fairly ok.
          Was suspecting 'airport proximity' readings to be wrong but it was a dead end.
          i am now chasing rabbit hole of not having reads on VN0R, TG1D & TW0P.
          @gurangax can you please check if you are getting the values at all? Presumingly you are on MBP8,2/EMC2563?
            Finally, SOLVED!!!
            Put it on a shelf for some time and in the meantime I got my hands on a replacement A1382 battery made by 2power. Yes, a non-genuine Chinese knock off...
            Lo and behold, no more throttling!!!
            So new replacement A1382 battery from unknown manufacturer, even though correctly reported, charging up and in 'good' OS condition = throttling
            Original battery from A1278 (same connector but different capacity) = throttling
            Turns out that apart from GPU throttling issue which was the initial problem, the last piece of the puzzle was 'incompatible' battery. This is unbelievable. Gotta love Apple...
            I wonder what they did exactly... blacklisted the serial?
            'throttling' battery #1
            Code:
            Model Information:
             Serial Number:	W01484ND2D3BA
             Manufacturer:	SMP
             Device Name:	bq20z451
             Pack Lot Code:	0
             PCB Lot Code:	0
             Firmware Version:	201
             Hardware Revision:	000a
             Cell Revision:	158
             Charge Information:
             Charge Remaining (mAh):	6575
             Fully Charged:	No
             Charging:	Yes
             Full Charge Capacity (mAh):	6976
             Health Information:
             Cycle Count:	5
             Condition:	Normal
             Battery Installed:	Yes
             Amperage (mA):	577
             Voltage (mV):	12466
            Original A1278 battery (throttling):
            Code:
            Model Information:
             Serial Number:	W053001C9D3BB
             Manufacturer:	SMP
             Pack Lot Code:	0
             PCB Lot Code:	0
             Cell Revision:	158
             Charge Information:
             Charge Remaining (mAh):	4837
             Fully Charged:	Yes
             Charging:	No
             Full Charge Capacity (mAh):	4927
             Health Information:
             Cycle Count:	1805
             Condition:	Normal
             Amperage (mA):	0
             Voltage (mV):	12441
            2power battery (working fine!)
            Code:
             Model Information:
             Serial Number:	C01514309YEF90MA4
             Manufacturer:	2-power
             Device Name:	A1382
             Pack Lot Code:	3230
             PCB Lot Code:	30db
             Firmware Version:	ddae
             Hardware Revision:	dac2
             Cell Revision:	2b39
             Charge Information:
             Charge Remaining (mAh):	7359
             Fully Charged:	Yes
             Charging:	No
             Full Charge Capacity (mAh):	7360
             Health Information:
             Cycle Count:	1
             Condition:	Normal
             Amperage (mA):	0
             Voltage (mV):	12233
              Maybe its looking for battery full charge capacity of more than 7000mAh for it to enable full speed
              • cruiser_
                cruiser_ commented
                Editing a comment
                Good spot and an interesting idea. I wouldn't be surprised if Apple actually implemented something like that
