Macbook Pro A1707 Indicates charging even with no power adapter connected.
  • CAPTGENE
    • Mar 2023
    • 8
    • New Zealand
    Hey guys. I have a Macbook Pro A1707 that indicates charging even with no power supply connected. The Macbook is working normally except for the wrong battery charging indicator. Where in the schematic diagram should I start looking for anomalies? Thanks in advance.
  • mon2
    • Dec 2019
    • 14634
    Re: Macbook Pro A1707 Indicates charging even with no power adapter connected.
    What do you see for the details of your battery?
    https://support.apple.com/en-ca/HT201585
    What is the 820-**** of your logic board?
    • CAPTGENE
      • Mar 2023
      • 8
      • New Zealand
      Battery Cycle count is 346 and normal condition. Logic board 820-00928-A. I swapped with a known good Logic board and it charged normally.
      • mon2
        • Dec 2019
        • 14634
        Try a SMC reset.
        https://apple.stackexchange.com/ques...d-to-power-sou
        • CAPTGENE
          • Mar 2023
          • 8
          • New Zealand
          Thank you, Mon2. My problem was fixed by an SMC reset.
          • TimScrawn
            MacBook Pro A1707 820-00928-A No power not turning on or charging
            by TimScrawn
            Got a very strange one here. Got an A1707 that came in dead no power. Plugged into amp meter and get 5v and then power cycles. After removing the board from the housing, I get 5v on all 4 ports with no amp draw, but it stays at 5v. I then check all rails:
            PPBUS_G3H - 2.3v - Not shorted (1.8 megaohms)
            PP3V3_G3H - 3.3v
            PP1V8_UPC - 1.8v
            PP3V3_UPC - 3v3v
            D6902 - 3.3v on pin 1 & 3
            I then saw these readings and thought, classic ISL9239 issue
            Removed ISL and replaced with donor board. Mac powered up to 20v and drew around 300mah
            10-04-2025, 04:59 AM
          • robka
            MacBook Pro 2018 - A1990 Dead - not charging - only 5V
            by robka
            my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
            I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
            The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
            After that the Macbook was dead. It isn't charging anymore.
            The USB-C Port where the charger was plugged is burned. Also The Cable and the...
            03-02-2024, 02:58 PM
          • CG_Dionysos
            MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
            by CG_Dionysos
            I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
            • Model: A1707
            • 15-inch, Mid 2017
            • 3.1 GHz Core i7
            • 16 GB RAM
            • Radeon Pro 560
            • 1 TB SSD
            • Board number: 820-00928-A
            I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
            Thanks in advance!
            Greetings from Germany...
            09-16-2025, 06:43 AM
          • Gueric
            Macbook Pro M1 (A2338) 820-02020 not charging.
            by Gueric
            I returned home from college. My MacBook battery was flat. Plugged it in. Nothing. Won’t boot. Waited for an hour. Nothing.
            When plugging the charger : 20v at 0.02 amps.
            pressing any key will make the « low battery » icon show up. Then switch to 5v and 420mA constant. Trackpad clicks, keyboard works.
            Decided to put the board into another M1 body with a charged battery, it’s booting perfect, still 5v and 420mA tho, and battery is not charging.
            I diode moded every pin of U5200 and they’re all fine. I know very little about Apple silicon machines...
            07-23-2025, 01:54 PM
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
