Got a macbook air that fails to boot from any drive be it external or internal. It just shuts down when the progress bar is about 25%. After it's off i can turn it on normally with the power button. I tried flashing a clean ME efi but there wasnt any difference. What could be the issue here? I can take measurements on the board if needed. There is a bit of liquid damage on the back of the board. I uploaded it to the drive folder. And also here's the video footage. https://drive.google.com/drive/folde...DzIb6YHjc9RMvh
Macbook air a1369 emc2469 boot issues
Re: Macbook air a1369 emc2469 boot issues
Please attached the picture using the forum servicesGot a macbook air that fails to boot from any drive be it external or internal. It just shuts down when the progress bar is about 25%. After it's off i can turn it on normally with the power button. I tried flashing a clean ME efi but there wasnt any difference. What could be the issue here? I can take measurements on the board if needed. There is a bit of liquid damage on the back of the board. I uploaded it to the drive folder. And also here's the video footage. https://drive.google.com/drive/folde...DzIb6YHjc9RMvh
and that board need to be cleaned first contact cleaner a mild brush will do. and tryy to update, maybe a corroded solder joint the chip cause this issue -
cleaned with alcohol and no difference. Do you think a solder reflow would help?Comment
by Flasman90I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
- "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
- "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
...08-30-2025, 10:27 AM -
by twonk9098I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
This model has the newer trackpad which is not clickable when turned off.
At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but... -
by PITERPENYThe MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.01-05-2025, 03:11 PM
by Sergio KubCould someone help me?
I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
Could it be the BIOS? -
Could it be the BIOS? - Loading...
