HP 15-dw3000 strange problem
  • mo000
    • Nov 2017
    • 277
    • algeria
    hi
    HP 15-dw3000
    gpt52 la-k201p rev 3
    comes with black screen
    all voltages are present
    i try to flash the bios but same problem
    the power on with 0.8amps consumption
    i notice something strange
    the cpu becomes very hot but the fan not turning on
    but the fan is working fine because it's spinning and stop when the laptop power on
    i assume the cpu is defective .
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 15-dw3000 strange problem
    Hp's usually have fan as always on -so fan should be spinning all the time. but that should'nt be the focus point. You have not shared any measurement-so cant say anything about cpu. start with resistance to GND on all coils.
    • mo000
      • Nov 2017
      • 277
      • algeria
      no short on all coil and the reading is normal .
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        based on hoow normal is the reading, better elaborate it more
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • jacospama
          gpt52 la-k201p rev 1.0 boot problem
          by jacospama
          HP Laptop PC 15-dw3000 (1A3X9AV) (gpt52 la-k201p rev 1.0) if i press the power switch it turns on without signal then goes of within 5 seconds. what might be the problem
          11-11-2022, 06:53 AM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
        • sopik78
          HP 250 G8 GPT52 La-k202p backlight problem
          by sopik78
          Hello, I have an issue with the backlight on my HP 250 G8 laptop. Here are the voltage readings:
          • INVPWR_B+: 19V
          • +LCD VDD: 3.3V
          • INVTPWM: 3.3V
          • It does not have a touchscreen.
          Could someone advise me on what else to measure? I've already tested two different LCD panels.
          04-14-2024, 11:54 AM
