HP 250 G8 GPT52 La-k202p backlight problem
  • sopik78
    • Nov 2013
    • 517
    • Czech Republic
    Hello, I have an issue with the backlight on my HP 250 G8 laptop. Here are the voltage readings:
    • INVPWR_B+: 19V
    • +LCD VDD: 3.3V
    • INVTPWM: 3.3V
    • It does not have a touchscreen.
    Could someone advise me on what else to measure? I've already tested two different LCD panels.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    DISPOFF# reading?
    • sopik78
      • Nov 2013
      • 517
      • Czech Republic
      Sorry. my mistake:
      INVTPWM 0.67V
      DISPOFF# 3.2V
      • mon2
        • 14136
        INVTPWM 0.67V
        Low inverter backlight voltage. At 3v3 the backlight will be 100% on.
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
        • DanPoka
          by DanPoka
          02-15-2025, 05:05 AM
        • Comp_Pro
          No Backlight Macbook A1990 820-01041
          by Comp_Pro
          Hello all,
          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
          Tests performed:
          There is no backlight even with a good screen.
          Backlight IC is receiving the correct support voltages.
          Fuse F8400 ok
          Current sense resistor R8400 ok
          Backlight IC is receiving 3.3V on enable pin.
          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
          Backlight IC receiving 5V from PP5V_G3S
          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
          05-06-2024, 10:23 PM
        • cheebster
          iPad Pro 12.9 5th Gen Backlight Issue
          by cheebster
          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
          Anyone...
          05-20-2025, 09:17 AM
        • canadaboy25
          LG Flatron 24EN33TA No Backlight When Cold
          by canadaboy25
          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
          03-07-2023, 12:23 AM
