gpt52 la-k201p rev 1.0 boot problem
  • jacospama
    • Aug 2019
    • 240
    • Ghana
    HP Laptop PC 15-dw3000 (1A3X9AV) (gpt52 la-k201p rev 1.0) if i press the power switch it turns on without signal then goes of within 5 seconds. what might be the problem
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: gpt52 la-k201p rev 1.0 boot problem
    Always begin with basic requirements of SIO.
    • Ali5914
      • Dec 2020
      • 48
      • India
      Try fresh bios.
      • andrew25
        • Feb 2016
        • 223
        • Malawi
        i have same problem, even after flashing fresh extracted bios from hp site... turns off after 5 sec.. power LED
        • m.tech
          • Aug 2024
          • 25
          • Italy
          Hi, I have the same problem, how did you solve it? Thanks
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Monitor SUSP#
            • m.tech
              • Aug 2024
              • 25
              • Italy
              Monitor SUSP#
              Sorry, I didn't understand, can you explain? Thanks
              PS I use the translator​
              • m.tech
                • Aug 2024
                • 25
                • Italy
                Hi, how did you solve it? I have the same problem. Thanks
                • lapfix
                  • Mar 2020
                  • 2756
                  • my workshop
                  HELLO FRIENDS
                  got the same motherboard , come to me after a liquid damage
                  power on , cosumption reach 044 amp...than few seconds and off.
                  find some corrision ( clean it )and change 1 damged componenet ( changed ) but still the same behaviour
                  follow the power sequence page 3..all is good until i reach . (32) PM_SLP_S3#
                  tested at pin 71 of UK1
                  pin 71 = 0.279 v very low
                  Resitance = 059.3 Kohm
                  Any idea ; is it a bad or damaged PCH !
                  Schematic - https://www.badcaps.net/forum/troubl...gpt52-la-k201p
                  • futadmytro
                    Asus g713qm-es94 stuck on boot bios problem
                    by futadmytro
                    sn^M4NRKD02753616E
                    MB- g533-6050a3250201-MB-A03
                    Stuck on boot after ROG logo, did not enter to bios
                    In flash bios , laprop boot but have video issue
                    orig bios...
                    06-25-2025, 08:07 AM
                  • mpower1226
                    Dell optiplex 7090 boot problem
                    by mpower1226
                    Hi masters, need your help in solving this mystery.
                    i have a dell optiplex 7090 micro that i bought from local kijiji.
                    when i turn it on, error comes out saying no hard disk.
                    i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
                    i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
                    it seems as if the computer doesnt recognize the ssd...
                    01-22-2024, 10:37 PM
                  • privato89
                    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                    by privato89
                    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                    Let's begin:
                    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                    03-26-2024, 06:37 AM
                  • litsnsirn
                    HP Z620 boot from NVME problem
                    by litsnsirn
                    I have been trying to build myself up a Z620 workstation for a while now, and I think I finally have all of the parts that I need and this is giving me gout. It's my understanding that that as long as you have the newest firmware, one is supposed to be able to boot from a NVME drive in a Z620 workstation.
                    There are lots of different posts across the internet and they don't all seem to agree with one another and a lot have old, outdated information.
                    I have the official Z-Turbo adapter cards; I've tried a HP branded Samsung SM951, as well as a couple of other drives...
                    02-08-2023, 06:32 PM
                  • rxyzm
                    MSI GL63 (Board 16P51, Rev 1) Laptop - Boot Problem
                    by rxyzm
                    I am working on MSI GL63 that also has 16P51 (Rev 1, I think) board.
                    This is gaming laptop.
                    Last few weeks, I have been noticing following symptoms -
                    1. When the laptop is switched on, the power button shows blue light for a long time. The machine may or may not boot after the time. (Usually, when the power switch is pressed, it would show blue light for couple of seconds. After that, the keyboard LEDs (RED Color) turn on and the power switch shows red light, machine boots)
                    2. The laptop may try to boot by doing power cycling 3, 4, 5,...
                    11-20-2022, 09:12 AM
