s340-15IWL Laptop stops charging until AC and battery are disconnected
  • mrkmpn
    • Apr 2022
    • 62
    I have a Lenovo IdePad s340-15IWL that will charge fine to 100%, but if you let the battery drain to around 50% (give or take) and plug the AC adapter back in, it will no longer charge and the only way to resolve the issue is to disconnect the AC adapter, disconnect the battery, plug the battery back in, and then the AC adapter, and then it will once again charge the battery back to 100%.
    If you unplug the AC adapter and let it drain down a little and plug it back in, charging still works fine. I'm not 100% sure where the cutoff is where it stops working, but I think it's down around 50-60% or so.
    I have tried a different battery and AC adapter, tried updating BIOS, but still have the same problem.
    Does anyone know what might be the cause of this, or what I can try to test?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Laptop stops charging until AC and battery are disconnected
    Check settings in battery management software,if installed. lenovo has such software for many models.
    • Sephir0th
      • Oct 2020
      • 1289
      Just a shot into the blue, but sometimes a partial failed PR324 or PD301 can cause such a behaviour. have dealt with faults in this area more than twice. Fast to check/rule out.
      FairRepair on YouTube
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • piernov
        Laptop battery charging circuit
        by piernov
        1. Some theory
        1.1. Introduction
        Almost every laptop has a charging circuit of some sort, that does a few things:
        • Manages switching between AC adapter and battery power
        • Manages battery charging and generates power rail to charge battery
        There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
        • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
        • Narrow VDC (NVDC)
        Texas instrument has a nice overview of these technologies with some more details at https:...
        11-15-2020, 01:31 PM
      • kodox
        ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
        by kodox
        since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
        the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
        what i've done:
        - flashing...
        12-29-2024, 02:49 AM
      • Shinju
        Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
        by Shinju
        Hey All!
        Long time forum member here with a problematic laptop issue!
        I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
        The laptop would not power on with the new battery installed without the power supply being plugged in.
        When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
        TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
        10-20-2021, 04:58 PM
      • Iherduleikgemz
        Asus FX505DY - Battery not charging - BQ24780S
        by Iherduleikgemz
        Hello everyone
        I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
        I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
        01-13-2025, 03:54 PM
