Asus tuf FX505du charging,but wont power on
  • kew1701
    • Nov 2013
    • 40
    • Poland
    Re: Asus tuf FX505du charging,but wont power on
    No more short,removed some tiny cap or resistor,near gpu mosfet....what next?
    • kew1701
      • Nov 2013
      • 40
      • Poland
      Ok,laptop powers on ,im in bios now ����
      I assume i will have no audio because L3606 burnt,where to find this,and do i need this cap or resistor at mosfet??
      • Sephir0th
        • Oct 2020
        • 1289
        Good job. Yeah, L3603 has to be replaced for getting the Audio circuit back and if there are doubts it is also the best replace the cap. So near to a mosfet it might be more important, than another cap which is just used as filter.
        FairRepair on YouTube
        • kew1701
          • Nov 2013
          • 40
          • Poland
          Thanks Sephir0th,i could not do it without U'r help...can i salvage such resistor and cap ,or i need to buy...because in circuit resistor has short ohm reading,maybe remove it then measure?
          • Sephir0th
            • Oct 2020
            • 1289
            Yeah, resistor measurements always out of circuit. This is a inductor though, so basically not a resistor.
            For the cap, pay attention to met the specifications: Same capacitance, same or higher voltage rating.
            Otherwise no issue to salvage from donor boards.
            • kew1701
              • Nov 2013
              • 40
              • Poland
              #26
              Yesterday i was measuring this cap near mosfet(this blown is 4 in row) and 3rd one had 2.7uf,is this my MM wrong,i even measured it out of circuit and again the same...is this 0603 size 4.7uf/6.3v?And L3603 is 3603 size 120ohm 100mhz(this one i surely can't measure cause i have aneng m118a)...jeez
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • ShadowAi
                ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                by ShadowAi
                Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                03-15-2024, 10:46 AM
              • meraklinetx
                Asus Z97-a power cycle, no boot no cpu voltage
                by meraklinetx
                Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                05-10-2023, 06:08 AM
