Asus A555L sudden power off
  • jaikumarpeddy@gmail.com
    JCS
    • Sep 2015
    • 12
    • India
    I have problem in Asus A555L modes with X555LD rev 3.6 motherboard. It gets on works for some time and suddenly goes off. DC power supply shows 0.02 amps, 5v,3.3v, ram1.3v present.then it doesn't get on for 3 4 hours. After that agains gets on works for some time and same problem...
    When I connect the charger motherboard starts automatically. What is the problem . please help..
  • mon2
    • 14338
    Re: Asus A555L sudden power off
    Be sure the adapter is the one recommended for the unit. The instant on upon adapter docking often is due to a leaky mosfet. Review the first 2 * DCin mosfets on the logic board. Which charger IC is onboard? Perhaps the BQ series?
    Trace the dcin connector and the mosfets will be close by. The mosfets will be 8 pin devices. Post all details.
    • TonyCajeta
      • May 2022
      • 15
      • Mexico
      How much current draws when it is working?
      Can you boot and read the CPU's temperatures?
      How much time you have before it shuts down?
        JCS
        • Sep 2015
        • 12
        • India
        When the laptop goes off, that time after putting it on it shows 0.02 amps on dc power supply and 5v, 3v, is ok but ram voltage 1.3v comes automatically without power on... but the laptop dosn't get on. I have checked everything nothing is short ... Charger is ok I changed it, cpu temperature ok not much heating , battery charging is also ok.. after keeping off for 3 to 4 hours it again starts properly.. What actually is I am not able to rectify...
          JCS
          • Sep 2015
          • 12
          • India
          any one pls help
          • mon2
            • 14338
            Post #2
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • ShadowAi
              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
              by ShadowAi
              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
              03-15-2024, 10:46 AM
            • meraklinetx
              Asus Z97-a power cycle, no boot no cpu voltage
              by meraklinetx
              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
              05-10-2023, 06:08 AM
