Acer Not Powering la-k701p
  • kalilinux25
    • Mar 2018
    • 2084
    • ZAMBOANGA SIBUGAY
    Re: Acer Not Powering la-k701p
    EC_RSMRST# -0v This is cause of concern. Without RSMRST# present, you cant expect get anything from PCH like PM_SLP_X. Try removing DB2/DB/3/DB4 one by one and see any changes happens or not. However, before RSMRST# 1.05V/1.8V ALW rails should be present.
    tried remove all db3 db4 db2 and tried to run display unit on start fan speed , 3 times unit restarted and until display is present. Ill try to stress test the unit if everything is totally functional sir.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Glad, you fixed it again. I suggested to remove these 3 diodes one by one so that we can identify which one is faulty. Perhaps you hurried up a bit.
      PS: That particular diode we're looking for may be faulty(very unlikely) or that voltage rail's powergood is missing. Usually replacing the PWM on that rail is recommended and test the unit with all the diodes soldered back for stability.
      • kalilinux25
        • Mar 2018
        • 2084
        • ZAMBOANGA SIBUGAY
        will it last without those diode? or do I ned to change a pwm and which one specificsir ?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          How i can confirm which PWM is responsible when you didnt removed them one by one.
          Yes, it should last without these diodes.
          • kalilinux25
            • Mar 2018
            • 2084
            • ZAMBOANGA SIBUGAY
            ill try it again sir one by one again to pin point the pmw sorry I hurried again without trying the basic steps mybad
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              #26
              Let it go this time but dont loose patience next time. Btw, i helped you fix this board twice in a row-so you owe me a coffee.
              • kalilinux25
                • Mar 2018
                • 2084
                • ZAMBOANGA SIBUGAY
                #27
                Thanks sir , Ill do my best during the process, im having a refresher course again because I stop doing repairs for a while .
                • tblazers
                  • Jun 2023
                  • 27
                  • New Zealand
                  #28
                  I have a similar issue, which diode ended up being the correct one that was removed? and did you jump it once it was removed ?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    #29
                    Diode should not be jumpered.One solution may not fit in all cases. Describe your problem details for better clarity.
                    • tblazers
                      • Jun 2023
                      • 27
                      • New Zealand
                      #30
                      Sorry i made my own post now here
                      https://www.badcaps.net/forum/showthread.php?t=120768
                      • EpicFix
                        • Aug 2024
                        • 43
                        • Trinidad & Tobago
                        #31
                        Hi guys, total noob here I have an Acer board in with “no power” issue. GH5JJ / GH7JJ LA-K701P Rev 1 C.
                        @ PRB3 I get 18v (7Mohms)
                        19v comes up to PCB8, PCB9, PCB10 but nothing goes into PQB5.
                        Side note:
                        PC501, PC506, PC503, PC504, PC505 all continuous with ground on both ends but the shorts are released when PU501 is removed.
                        PL502 is also continuous to ground on both ends (along with all the caps PC508 to PC513) even after PU501 is removed.
                        If anyone can offer me some guidance on where I can check next I'll be super grateful. How / where do I detect shorts?
                        • mon2
                          • Dec 2019
                          • 14088
                          See attached. This means everyone to the RIGHT side of this PU501 is a suspect.
                          I would start with checking the USB connectors since VBUS is used to power the USB devices. The local load switch often fails.
                          Remove all power. Meter in resistance mode. What is the exact resistance to ground of +5VALW_USBA? If the resistance is ok and not a short, move onto reviewing JPQ3. Remove this short / solder blob.
                          Is the short condition now gone?
                          • EpicFix
                            • Aug 2024
                            • 43
                            • Trinidad & Tobago
                            #33
                            I checked @ UT10 the resistance is 2.2 Ohms. Is that a short?
                            • mon2
                              • Dec 2019
                              • 14088
                              100% a short. Flux and remove this part. Then test if the short is gone or not.
                              • EpicFix
                                • Aug 2024
                                • 43
                                • Trinidad & Tobago
                                #35
                                Removed...... still shorts. PL502 is also continuous to ground on both ends (along with all the caps PC508 to PC513)
                                • mon2
                                  • Dec 2019
                                  • 14088
                                  Remove the solder blob @ PJ501. This will isolate the 2 sides of this shorted rail. Then measure each side of the removed solder blob.
                                  Which side is still shorted?
                                  • EpicFix
                                    • Aug 2024
                                    • 43
                                    • Trinidad & Tobago
                                    #37
                                    PJ501 removed. Shorts gone from PL502 and the surrounding caps (PC508 to PC513). Resistance @ UT10 now 7.8 Ohms @ PIN 5, 13 MOhms @ PIN 1 (both readings done with the component removed). I checked the component off-board PINS 1,2 and 5 are continuous. The pads on the board for UT10 (PIN 2 and PIN 5) are continuous between themselves and also to ground. Is that still shorted? Where do I go next?
                                    • mon2
                                      • Dec 2019
                                      • 14088
                                      Would you have a thermal camera?
                                      • EpicFix
                                        • Aug 2024
                                        • 43
                                        • Trinidad & Tobago
                                        #39
                                        Yes I do, but its not a very good one FLIR C5. I also have a bench supply and a "short killer" / voltage injection tool. It's reading schematics and figuring out problem circuits I'm a noob at 🤣
                                        • mon2
                                          • Dec 2019
                                          • 14088
                                          We too have the 'short killer 30A' !! Good taste. My only complaint is that the display is a bit dim from day #1 so not supper happy with the vendor.
                                          Be 100% that the pin with the low resistance is not ground. Fairly confident that you are doing this properly so far. Dial up 0v8 on the display. We want to keep the voltage as low as possible. Then apply the short killer onto the pad with the low resistance. Check who heats up. Hope it is a capacitor. The injection should smoke out the shorted part.
                                            09-06-2024, 05:27 AM
                                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 05:00 AM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            Acer Swift SF314-511-79X5 + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift SF314-511-79X5 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-79X5 + Pack Gold Acer 14'' boardview and SF314-511-79X5 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 03:10 AM
