Acer Not Powering la-k701p
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hi goodday to all , Im having a quite issue, if the PU301 si need replacing because I dont have any parts avalble, and needed it to be ordered overseas.
    Unit wont power, no water damage and corrosion, unit was not used for almost a year (customer said)
    BOARD: GH5JJ/GH7JJ LA-K701P REC:1C 2021-01-08
    MAINPWON 3.3v goes 1.2v every 5 sec
    PU301 READING
    1.BST- 3V
    2,3,4,5 - +19VB_3V- 19V
    6. LX_3V - 0V-
    7,8 - GND
    9. SPOK_3V
    10. NC
    11. ENLDO_3V - 4.4V STABLE
    12.3V_EN -0V
    13. 3V_FB - 0V
    14.+3VALWP- 0V- not shorted kilo ohms reading 4k
    15.NC-
    16,17. +3VLPP- 3.3V
    18.GND
    19,20- LX_3V- 0V
    +3VLP 3.3V STABLE
    EC_ON
    3.3V STABLE
    5V_3V_EN 3.3V
    PCH_DPWROK 0V
    +RTCVCC 3.1 V no cmos connected
    3V_EN_R 0v RB16 1k ohms reading resistor ok not shorted on both sides
    ON/OFFBTN# 3.3v if pressed goes 0v and back to 3.3v
    Link to schematic -> https://www.badcaps.net/forum/troubl...c-or-boardview
  • reformatt
    • Feb 2020
    • 1533
    Re: Acer Not Powering la-k701p
    Power cycling of the enable is EC not getting a power good from PU301 (or something further down in the power sequence).
    Check the boost and feedback circuits first before blaming the IC.
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      Which feedback circuit sir? sorry for bad english
      • chenwei
        • Feb 2023
        • 40
        • china
        Placed a year of machine, it is recommended that the replacing PL302 inductance
        • reformatt
          • Feb 2020
          • 1533
          PC302, PC315, PR306 etc. I could count on one hand the number of inductors I've had fail.
          • kalilinux25
            • Mar 2018
            • 2093
            • ZAMBOANGA SIBUGAY
            Hi sir this is what I got
            RESISTANCE TO GROUND READINGS
            PC302- 2.6Mohms pin 2 to ground
            PC305 - non stuff ( not present on board)
            PL302 - 3.9k to ground
            RB16- 1K value ok
            RB17- 1MK ok
            PC315- 4.0Momhs
            PR303- 150K ok
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              DB1,pin1 MAINPWON present??
              • kalilinux25
                • Mar 2018
                • 2093
                • ZAMBOANGA SIBUGAY
                DB1
                PIN1 - 3.3V stable sir
                Thank You for checking by sir
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Remove RB16 & RB17 and DB1. Jumper DB1 between both pads. Hope you will have a working machine back.
                  • kalilinux25
                    • Mar 2018
                    • 2093
                    • ZAMBOANGA SIBUGAY
                    Thanks sir Ill try and update
                    • kalilinux25
                      • Mar 2018
                      • 2093
                      • ZAMBOANGA SIBUGAY
                      Thank You sir , Unit now is fully working at no issue at all, my I ask why do I need to remove those resistor and diode? please illaborate it to me , thanks
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Glad to know that. Have a look at the schematic and answer lies there. We've just bypassed "thermal protection". Common issue on many acer models-Whatever you do, this protection doesnt go away and i dont know why.
                        • kalilinux25
                          • Mar 2018
                          • 2093
                          • ZAMBOANGA SIBUGAY
                          So means the unit wont tart becasue of the thermal protection.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Yes and this trick will help you on many acer boards with same issue and the solution is same-to bypass thermal protection.
                            • kalilinux25
                              • Mar 2018
                              • 2093
                              • ZAMBOANGA SIBUGAY
                              Sir update after 2 days unit response became same, no shorted test voltage on the jumper of DB1 it has 3.3v
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Perhaps a new fault and unrelated to earlier repair. So need to probe from the beginning.
                                • kalilinux25
                                  • Mar 2018
                                  • 2093
                                  • ZAMBOANGA SIBUGAY
                                  ok sir , 3v and 5v is present as always pwoer button has 3.3v and unit is only consuming 30milliamp and also tried flashing from acer website
                                  • kalilinux25
                                    • Mar 2018
                                    • 2093
                                    • ZAMBOANGA SIBUGAY
                                    Fan just turn and stop and unit goes no power no led indicator present
                                    • kalilinux25
                                      • Mar 2018
                                      • 2093
                                      • ZAMBOANGA SIBUGAY
                                      3V_EN -3.3v
                                      PCH_DPWROK -0v - not shorted
                                      SLP_SUS# - 0v
                                      PCH_PWR_EN -0v
                                      +1.8VALW - 0v
                                      EC_RSMRST# -0v
                                      AC_PRESENT - 0v
                                      SYSON - 0v
                                      +3VLP_EC -3.3v
                                      +3VLP - 3.3v
                                      AC_IN - 3.2v
                                      LID_SW# -3.3v
                                      SUSP# - 0v RST ( resistance to ground ) 10koms
                                      +5VALW -5.1v
                                      PM_SLP_S3# - 0v
                                      PM_SLP_S4# -0v
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        EC_RSMRST# -0v This is cause of concern. Without RSMRST# present, you cant expect get anything from PCH like PM_SLP_X. Try removing DB2/DB/3/DB4 one by one and see any changes happens or not. However, before RSMRST# 1.05V/1.8V ALW rails should be present.
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Swift SF114-34-P2CV + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF114-34-P2CV + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2CV + Pack Gold Acer 14'' boardview and SF114-34-P2CV + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 03:10 AM
