Asus GL703GM short
  • retrorepair2
    • Feb 2023
    • 92
    • United Kingdom
    #61
    Re: Asus GL703GM short
    Got MATS working, there's a UEFI image out there which works great, just be aware you'll always get 32 or so errors on the VRAM test.
    Found the chip I'd messed up and reflowed it again, back to my random little glitches and the card is once again working in windows.
    Decided to look at the battery situation again. I notice the charge is going in cycles, 8v, 0v, 1v, 0v, repeat. Is that normal? The battery did also have a blown fuse, gave it a tiny blob of low melt solder, still won't charge. I even tried to jump start the process in case the charge was too low by feeding it the 8v directly to the cells. It held the charge but the computer still won't charge it and reports 0%.
    I think the battery may be locked but I'm not too sure really. It's annoying as the wear is only 40% and I'm sure it only blew the fuse due to the short created bybthe original liquid spill. I'm not really keen to throw another 70 quid at this, any ideas?
    Outside of gaming, it's still a solid laptop for work stuff and has lots of grunt and screen real estate. If the GPU is indeed just screwed I'm keen to use it as my work machine. Just need to figure out that battery issue.
    • retrorepair2
      • Feb 2023
      • 92
      • United Kingdom
      #62
      Ok, so the battery is 15v yet this laptop is only putting out 8v on the battery connector, that's not right is it. What could I look at to see what's wrong here?
      • mon2
        • Dec 2019
        • 14660
        Which charger IC is onboard?
        Remove all power and check the resistance of each mosfet that is linked to the charger IC.
        Source & Drain
        Source & gate
        Gate & Drain
        Checking for low resistance readings.
        • retrorepair2
          • Feb 2023
          • 92
          • United Kingdom
          #64
          Its a BQ24780S.
          None of the mosfets in the charging circuit are short to any other pins, all in the megs.
          Coukd it be the IC? I did readings on the usual pins a few pages back and all seemed normal.
          • Sephir0th
            • Oct 2020
            • 1289
            Originally posted by retrorepair2
            I also found one of the DCin mosfets was shorted to all pins. I'm almost 100% sure I checked this the other day so no idea what that was about. Pulled a fet from a parts board and fitted it, confirmed no more shorts, powered up and got 26v. A small, insignificant win as by this point, every time I load windows and the screen dims, it shuts off. The GPU I think is almost dead.
            If anyone has any other thoughts I'm all ears but I don't think there's much hope for this laptop now. Unless I'm ok to run it in safe mode forever.
            Yeah, i have the thought, you didn't mentioned the model of the defective Mosfet and the model of the replacement so far. Did you prove it is suitable?
            FairRepair on YouTube
            • retrorepair2
              • Feb 2023
              • 92
              • United Kingdom
              #66
              It's the same model. Since that quote though, a lot has happened and the laptop now stays on until it's turned off. There's a GPU issue but that's for another day and doesn't affect general use.
              The battery charging is making me a little crazy though.
              The battery mosfets get 19v but put out 8v. It's just weird. What I need to know at this point is, should they be putting out 15v as this is what the battery is?
              • Sephir0th
                • Oct 2020
                • 1289
                Well, it is either a fault in the charging circuit or a dead battery. But I think you should be aware of guess work lead to nowhere here. Experienced technicians teach to replace the battery first. Alternatively after a complete measurement of the charging controller (voltages and resistances) something might turn out or maybe not.
                • MiwaSchlawiner
                  • Jan 2024
                  So I found the boardview for GL702 which looks to have a similar looking +NVVDD power generation circuit so I'm going to take a look today and try to narrow my short to a specific rail
                  How can i open the File? I got an error called "Invalid FZ key"
                  • Vesko356
                    Vesko356 commented
                    Editing a comment
                    Use the BoardViewer software - it's within the archive along with the boardview file.
                  ASUS ROG GL703GM-WH72 Notebook Strix Specification for Upgrade or Repair
                  This specification for the ASUS ROG GL703GM-WH72 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GM-WH72 boardview and GL703GM-WH72 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                  09-06-2024, 07:46 AM
                  ASUS ROG GL703GM-E5055T Scar Edition Notebook Strix Specification for Upgrade or Repair
                  This specification for the ASUS ROG GL703GM-E5055T Scar Edition Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GM-E5055T Scar Edition boardview and GL703GM-E5055T Scar Edition schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                  09-06-2024, 07:05 AM
                  ASUS ROG GL703GM-71250-GAMING Notebook Strix Specification for Upgrade or Repair
                  This specification for the ASUS ROG GL703GM-71250-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GM-71250-GAMING boardview and GL703GM-71250-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 07:02 AM
                  ASUS ROG GL703GM-EE063T Scar Edition Notebook Strix Specification for Upgrade or Repair
                  This specification for the ASUS ROG GL703GM-EE063T Scar Edition Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GM-EE063T Scar Edition boardview and GL703GM-EE063T Scar Edition schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                  09-06-2024, 06:31 AM
                  ASUS ROG GL703GM-E5108T Notebook Strix Specification for Upgrade or Repair
                  This specification for the ASUS ROG GL703GM-E5108T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GM-E5108T boardview and GL703GM-E5108T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 11:30 AM
